groovyclam Posted April 23, 2011 Posted April 23, 2011 I am in the UK using DVBViewer 4.8 on WinXP SP3 with a DVB-T USB device. I suppose this is not strictly a bug but it is very annoying and I would like a fix. If I tune to a channel with an autostartup MHEG overlay and the MHEG overlay tells the system to mute the sound then DVBViewer does that fine and overything is great. However if I then tune to a *different* channel the sound is still on mute and I have to manually unmute the sound to start hearing the new channel. I suggest that DVBViewer should keep a note of the sound level BEFORE an MHEG overlay starts and when a user then leaves that MHEG or tunes to a new channel then the sound level that was set before the MHEG started should be restored automatically. Quote
John D Posted April 25, 2011 Posted April 25, 2011 My problem is a variation on this one. I find that the sound mutes on DVB-T radio channels as soon as MHEG-5 starts working. This is not the normal muting which is described in the first posting and which can be corrected by pressing M. I can't imagine that the MHEG-5 stream from the radio service provider asks for the sound to be turned off! However, the sound does come back on when I tune a TV channel. This turning off of the sound can't be intended by anyone and is clearly a bug. I have reported this elsewhere but I think that I may not have given enough detail and it may have been assumed to be the same as the problem described in the first posting, which it isn't. support.zip Quote
groovyclam Posted April 25, 2011 Author Posted April 25, 2011 I also get this problem as JohnD above. It isn't really the same as I describe at the top of the thread. What I describe is an annoying "feature" whereas what JohnD describes is a true BUG and needs fixing. JohnD - are you in the UK and mean the non-BBC radio channels such as talkSPORT, Smooth Radio, etc. ? That is when I experience your bug. Quote
John D Posted April 25, 2011 Posted April 25, 2011 Yes, I am in the UK. Greetings from sunny West Sussex. I get the bug on BBC radio channels. But I have now tried the non-BBC channels you mention and I get the same problem. Quote
groovyclam Posted April 25, 2011 Author Posted April 25, 2011 Hi JohnD - I am in the North West ( Winter Hill Transmitter ) - sorry, I also get the bug on the BBC radio channels as well. Have you gone through Digital Switchover where you are ? I have ( just in case that is an issue for the bug busters ). Quote
John D Posted April 25, 2011 Posted April 25, 2011 (edited) We have not gone through digital switch-over. So we have mixed digital/analogue (steam TV) for another year. (Hang MHEG-5! I like Ceefax.) I would not have thought that switch-over would be an issue. I would have expected all regions to get the same MHEG-5 content. There isn't even any regional news in this format. Correction. There is regional news but all regions are broadcast nationwide. Edited April 25, 2011 by John D Quote
