Peter Kraan Posted April 26, 2011 Posted April 26, 2011 Hi All I just installed latest version of DVBViewer and for some reason I have lost some keyboard functions. I can't get the main OSD menu to come up when I press ESC (I have default settings selected in input menu). Oddly the EPG comes up when I press E and teletext when I press V but no other keys work. Any ideas? I did a fresh install and using default skin. This all worked fine on 4.5. Cheers Peter Quote
Peter Kraan Posted May 3, 2011 Author Posted May 3, 2011 (edited) Please can anyone help me with this issue? I have tried another basic USB keyboard and same problem. Keyboard works fine in any other application but in DVBViewer only the plus minus keys, and E and V keys work. ESC RETURN and arrow keys do nothing. I tried a virtual keyboard on my iPad using Mocha VNC but that didn't work either. I can access menus etc with my mouse but not really practical on my TV as menu options are too small - I really need the large format OSD. Cheers Peter Edited May 3, 2011 by Peter Kraan Quote
Peter Kraan Posted May 7, 2011 Author Posted May 7, 2011 Have upgraded PC to windows 7 (clean install) and reinstalled DVBViewer and am using USB keyboard only but still no joy with OSD. Quote
desweil Posted May 7, 2011 Posted May 7, 2011 when you go to the input options in DVBViewer and then try to learn a "new" key for example for OSD menu and press ESC does it recognise it as ESC? Quote
Peter Kraan Posted May 8, 2011 Author Posted May 8, 2011 Hi Desweil No it doesn't recognise ESC when I try learn function. ESC works in other applications so thats not the issue. Quote
Peter Kraan Posted May 8, 2011 Author Posted May 8, 2011 When I press E for EPG DVBviwer shuts down entirely. Quote
Peter Kraan Posted May 8, 2011 Author Posted May 8, 2011 I might have found the issue. I go to input, click on LOAD and load the keyboard remote profile. Click apply and voila - keyboard works perfectly. But when I exit and then reopen DVBViewer it loses this setting and keyboard is non functional again. Quote
