Subtitles missing in TS player TV2 FilmHD Denmark ONLY!
krasno
Hi
I have a problem when cutting in TS player.
If I record from TV2 Film HD, danish channel, subtitles are fine when played in DVBViewer.
If I open same ts file in Ts player subtitles are gone. also if I cut and save.
Recorded audio channels and txt-TV are there and everything works, except for the subtitles.
All other recorded programs from other channels, works with subtitles, in TsPlayer and in DVBViewer as well.
I guess it's a problem from TV2-FilmHD, do they use other type of DVB Subtitles or?
For information I have the same problem if I use VideoRedo, again only from that channel!!
TV2 film HD can be recieved from 0.8W 10903H
Thanx for any good ideas :)
Try to increase Settings -> Search Depth for a deeper file inspection (e.g. 100 MB or more). The subtitles must show up in the Available Streams Field, otherwise the TSPlayer will ignore them.
Good morning:)
Ok I will try that later, goto to go to work..
Edited by krasno
Hello again:)
After some testings: it works, 5 at300Mb, one first at 900mb. dono why... :)
The sub's don't show up in TSplayer, only in saved recordings when played in Dvbviever.
That still goes for that channel only, and is of course not a problem :)
For others that run into this problem TSplayer need to be restarted before the changes in "search dept" takes action.
Thanx for your help!!
