Nolan Posted May 2, 2011 Posted May 2, 2011 DVBViewer 4.8 verursacht crash von kaspersky internet security 2011. I have spend many hours together with kaspersky support of finally isolating the reason that kaspersky internet security 2011 stop working when scanning. Its fue to the latest update of DVBViewer pro 4.8. The older version 4.5 does not have this issue. Please can you fix ? if I kill the process TTTvRc.exe scan of kaspersky works fine 1. where can I down load previous version eg 4.5 2. does DVBViewer work 100 % if I per default kill the process TTTvRc.exe - what is it good for ? Thanks Jorn support.zip Quote
Tjod Posted May 2, 2011 Posted May 2, 2011 2. does DVBViewer work 100 % if I per default kill the process TTTvRc.exe - what is it good for ? The TTTvRc.exe is not part of the DVBViewer. If I am right TTTvRc.exe has something to-do with the Terratec remote control and is installed with the the driver. Quote
Griga Posted May 2, 2011 Posted May 2, 2011 2. does DVBViewer work 100 % if I per default kill the process TTTvRc.exe - what is it good for ? TTTvRc.exe = Terratec Remote Control Editor. Part of the installed Terratec software, not of DVBViewer. DVBViewer doesn't need it, but I think it is necessary for using the Terratec remote control resp. converting RC commands to simulated keystrokes. DVBViewer receives the simulated keystrokes like keystrokes from the keyboard without knowing where they come from. DVBViewer doesn't play an active part in this context. Anyway - since virus scanners often enough killed DVBViewer, it would be a nice revenge. We will contact Terratec and ask them how they made it Quote
Nolan Posted May 3, 2011 Author Posted May 3, 2011 hi i got the same error again even after having killed TTTvRc.exe, thereafter i uninstaled DVBViewer and the problem was solve. so it definitely has got something to do with latest update of DVBViewer. anywhere where i can download older versions untill this is fixed ?? thanks Jorn Quote
amirhs Posted May 4, 2011 Posted May 4, 2011 While I'm also using DVBViewer 4.8 along with Kaspersky Internet Security 2011, they display no conflicts whatsoever. Anyway it's unlikely that DVBViewer Pro can stop a well-protected app like KIS 2011, so your problem apparently resides elsewhere. Quote
bogdan1980 Posted May 6, 2011 Posted May 6, 2011 (edited) Method 1:use latest terratec home cinema( it update tt remote) from terratec ftp. http://ftp.terratec.de/Receiver/TerraTec_HomeCinema/TERRATEC_Home_Cinema_6.22.00.exe Method 2: Some antiviruses like Kaspersky, AVG, ESSET, has EXCLUSION zones, put here an whole folder, exe, file, and antivirus will not scan this folder. In this way your files will be safe from deleting. Edited May 6, 2011 by bogdan1980 Quote
