mm1352000 Posted May 28, 2011 Posted May 28, 2011 Hi everyone exact TV-card model and used driver version Hauppauge Nova S Plus (92001), driver version 2.126.28225 (latest) type and chipset of the mainboard Asus P5W DH Deluxe - Intel 975x graphics card and used driver version Sapphire (AMD/ATI) HD4670, Catalyst 10.4 My problem is that DiSEqC switching does not work with my Hauppauge Nova S Plus tuner. I have access to two satellites - Optus D1 (160e) and Optus D2 (152e) - via an EMP Centauri Profi-Line 9x8 multiswitch: Simple A/committed port 1 (AA)/committed port 3 (BA) === Optus D1 Simple B/committed port 2 (AB)/committed port 4 (BB) === Optus D2 The Nova S Plus will tune any transponder on Optus D1, but it can't get any transponders from Optus D2 on the second set of inputs. I have two Pinnacle PCTV 7010ix cards and a TechnoTrend Budget S2 3200 and DiSEqC works fine with the satellite tuners on those cards. I'm testing with the latest versions of DVBViewer (4.8.0.1) and Transedit (3.7.2.0). I don't have WinTV so I can't test with that. I've tried the "stop stream while tuning" option as well as the "standard interface" off/on and the "internal network provider" enabled/disabled. None of those options seem to make any difference. support.zip Quote
Griga Posted May 28, 2011 Posted May 28, 2011 Which DiSEqC settings have you already tried for Optus D2? Quote
mm1352000 Posted May 29, 2011 Author Posted May 29, 2011 (edited) All of the predefined ones: A B AA AB BA BB I'm not sure if the multiswitch also supports uncommitted commands, but like I said, the other tuners that I own are able to use either B, AB or BB to switch to Optus D2. The multiswitch is connected as follows: (<input>. <DiSEqC port>, <polarity/voltage>, <22 kHz off/on>) 1. DiSEqC A, 13V, no tone => Optus D1 vertical 2. DiSEqC A, 18V, no tone => Optus D1 horizontal 3. DiSEqC A, 13V, 22 kHz => (currently unconnected) 4. DiSEqC A, 18V, 22 kHz => (currently unconnected) 5. DiSEqC B, 13V, no tone => Optus D2 vertical 6. DiSEqC B, 18V, no tone => Optus D2 horizontal 7. DiSEqC B, 13V, 22 kHz => (currently unconnected) 8. DiSEqC B, 18V, 22 kHz => (currently unconnected) Edited May 29, 2011 by mm1352000 Quote
Griga Posted May 29, 2011 Posted May 29, 2011 Something that might help: http://www.DVBViewer.tv/forum/topic/28267-no-4-way-diseqc-with-vista/page__view__findpost__p__223347 Quote
mm1352000 Posted May 30, 2011 Author Posted May 30, 2011 Thank you Griga I will check my current registry setting and *carefully* try to turn DCL off. I'll also try moving the Optus D2 inputs from 5 and 6 to 3 and 4 (port A + 22k, effectively high band port A) and see if that kind of switching will work. The multiswitch isolation between port A and port B is better than the isolation with 1-4 and 5-8 which is why I was using port B in the first place, but I might have no choice... Quote
mm1352000 Posted May 31, 2011 Author Posted May 31, 2011 (edited) Hi again Griga It looks like the 22 kHz tone doesn't work at all because high-band <--> low-band switching doesn't work either. Obviously that would explain why DiSEqC switching isn't working. My registry value for the LNB power is set to 6 (lowest voltage, DCL on) and I wasn't brave enough to change it. Maybe I'll pluck up the courage to change the registry value tonight. I just *really* don't want to damage the card... I'm beginning to wonder if the card was already damaged when I received it, but 13/18V switching works fine and port A low band reception works fine so this is a strange issue. I've emailed Hauppauge support to see what they have to say. Thank you for your advice. I'd welcome any other suggestions although as far as I am concerned this is no longer a DVBViewer or TransEdit bug. Edited May 31, 2011 by mm1352000 Quote
