arbist2005 Posted May 29, 2011 Posted May 29, 2011 (edited) Based on X-skin (DVBViewer) and black HD skin (enigma 2) 23-10-2011 release Beta 0.5 *some changes in menu style thanks to bl4ck ( some icons and pictures adapted from HD Glass mod bl4ck original post http://www.DVBViewer.tv/forum/topic/47229-hd-glass-mod-bl4ck/ ) *some optimization and fix *fix online , MyMovies and MySeries *Added myscrobbler 0.1.6 thanks to amontillado original post http://www.DVBViewer...n-for-DVBViewer *fix FAV edit menu ( does not appear in the previous version ) *change volume bar *enigma 2 skin icon *enigma 2 skin style *signal strength and many info in miniepeg ( video type , frequency , sat name , provider name ... ) miniepgvars.dll *added neutrino 1.22 channel list thanks to pmneo original post http://www.DVBViewer...__1#entry315830 in setup.xml (...\ProgramData\CMUV\DVBViewer) change <section name="Input"> <entry name="UseFav">1</entry> <entry name="FfavOne">1</entry> </section> to start fav number from 1 *some changes in minepeg *added Red Green Yellow Blue Buttom in NeutrionoCL Channel Video Recorde Picture and Music List X-skin Black glass beta 0.5.rar Edited October 25, 2011 by arbist2005 1 Quote
Cornfed Posted May 29, 2011 Posted May 29, 2011 Looks nice, but the password doesn't work with the archive. Quote
Bootross Posted May 29, 2011 Posted May 29, 2011 Awesome skin Thanks a lot, best skin for DVBViewer as far as I'm concerned!! Thanks, B. Quote
emco83 Posted May 29, 2011 Posted May 29, 2011 (edited) Yeah, the password is wrong. Please fix it. Very nice skin. Edited May 29, 2011 by emco83 Quote
arbist2005 Posted May 29, 2011 Author Posted May 29, 2011 Yeah, the password is wrong. Please fix it. Very nice skin. the password ahmedtunisia work fine and there is another link without any password http://www.multiupload.com/JTCCONDUHA Quote
arbist2005 Posted May 29, 2011 Author Posted May 29, 2011 update 29-05-2011 * added neutrinoCL 1.21 to support FAV number Update.rar Quote
Bootross Posted May 30, 2011 Posted May 30, 2011 The skin is brilliant buddy, have already made it with MiniEPG3 my default skin!! 1 thing the skin is lacking for me (well the family mainly lol) are the R/G/Y/B buttons/options for adding to favourites etc in Channel List/EPG/NuetrinoCL, is this something you will be adding in future or should I have go at editing myself? Cheers, B. Quote
Cornfed Posted June 8, 2011 Posted June 8, 2011 Superb skin! I am using it as my default skin now. Thanks! Quote
Bootross Posted June 13, 2011 Posted June 13, 2011 Great updates buddy - Keeps getting better Many thanks, B. Quote
shark2010 Posted June 14, 2011 Posted June 14, 2011 Great updates buddy - Keeps getting better Many thanks, B. Quote
shark2010 Posted August 10, 2011 Posted August 10, 2011 Superb skin! I am using it as my default skin now. Thanks! Quote
Vroniefan Posted August 11, 2011 Posted August 11, 2011 wird mymovies und myseries noch integriert?? ansonsten super skin danke mfg Vroniefan Quote
arbist2005 Posted August 12, 2011 Author Posted August 12, 2011 wird mymovies und myseries noch integriert?? ansonsten super skin danke mfg Vroniefan in progress Quote
GaLaTaMaN Posted September 3, 2011 Posted September 3, 2011 Excellent work, the first competitor against coincitty skin since a long time Quote
Guest sasa Posted September 4, 2011 Posted September 4, 2011 many thanks from Egypt my friend viva Tunesia Quote
mikevd Posted October 9, 2011 Posted October 9, 2011 (edited) in eigenen Thread verschoben Edited October 21, 2011 by mikevd Quote
Herzog Posted October 10, 2011 Posted October 10, 2011 Wow!! Das Original ist schon sehr gut, aber der Mod: EIN TRAUM. Super Arbeit!! DANKE Quote
Vroniefan Posted October 10, 2011 Posted October 10, 2011 super mod danke dafür jetzt fehlt nur noch die mymovies und myseries Unterstützung wenn das noch jemand hinbekommt wird es mein neuer Standard skin darum die bitte macht mymovies und myseries möglich thx in advance Vroniefan Quote
Herzog Posted October 10, 2011 Posted October 10, 2011 mymovies und myseries!! wenn das funktionieren würde... wie geil wär das denn!!! Quote
Stinkbärchen Posted October 10, 2011 Posted October 10, 2011 Hi, well done Ist das so gewollt, dass bei NeutrinoCL die Liste bei Bestätigung mit okay sich nicht ausblendet? Wenn ja, wie kann ich das ändern? THX 1 Quote
razer2007 Posted October 11, 2011 Posted October 11, 2011 Sieht super aus, aber in der Timeline und der Timereinstellung sieht man keinen Auswahlbutton (Select-Button). Quote
BALOU Posted October 11, 2011 Posted October 11, 2011 Hi, well done Ist das so gewollt, dass bei NeutrinoCL die Liste bei Bestätigung mit okay sich nicht ausblendet? Wenn ja, wie kann ich das ändern? THX neutrinoCl.ini mit einem Editor öffnen und so ändern CloseOnTune=1 Quote
ramonchin Posted October 12, 2011 Posted October 12, 2011 Hi! How can I set OSD transparence level? The signal strenght level doesn't work with Sat channels but terrestial... How can I fix that? Thanks for your help Quote
Stinkbärchen Posted October 12, 2011 Posted October 12, 2011 Hi, besteht die Möglichkeit, sich die Senderlogos mit einem weißen Hintergrund anzeigen zu lassen? Ich benutze die Logos hier ausm Forum, die Sky Logos sind z.B. transparent mit schwarzer Schrift. Da sieht man natürlich nichts. Wie beschrieb einst Otto die ostfriesische Nationalflagge: weißer Adler auf weißem Grund. Quote
mague Posted October 14, 2011 Posted October 14, 2011 Hi, besteht die Möglichkeit, sich die Senderlogos mit einem weißen Hintergrund anzeigen zu lassen? Ich benutze die Logos hier ausm Forum, die Sky Logos sind z.B. transparent mit schwarzer Schrift. Da sieht man natürlich nichts. Wie beschrieb einst Otto die ostfriesische Nationalflagge: weißer Adler auf weißem Grund. Ich habe eine Handvoll weisser Sky Logos auf der Seite meiner OSD Skin. Sind die selbe Qualitaet nur invertiert. Siehe Signatur. Quote
Stinkbärchen Posted October 15, 2011 Posted October 15, 2011 (edited) Hi arbist2005, at first I want to say thanks for your beautiful skin and I apologize me for my bad english. I have found a few little bugs. Is it possible to fix it? 1. Look at the photo . Some broadcast title in Neutrinocl are to long and overlap the timestamp. 2. The language in your skin frequenty changes between French and English. Look at the photo . Would a complete English language possible or better can you install the German language? 3. Look at the photo . On the left its always called "Favoriten". What does this mean? 4. There are some black broadcast logos I can´t see this logos because the background in your skin is black to. There is a patch for the default skin to make a white background. Look here patch Is it possible to put in in your skin? Many thanks in advance Edited October 15, 2011 by Stinkbärchen Quote
Herzog Posted October 16, 2011 Posted October 16, 2011 (edited) @ mikevd X-Skin Black Glass MOD 1.2 ..jetzt ist es perfekt!!!!! Ein Super Mod. Vielen Dank nochmal. Du bist der Beste!! LG Edited October 16, 2011 by Herzog Quote
tbuk00 Posted October 17, 2011 Posted October 17, 2011 Bei mir läuft das MyVideos Plugin noch immer nicht. im OSD wird nichts angezeigt. Also fehlen tut nichts. Mit anderen Skins geht alles. Ist eine sauber Arbeit! Leider..., siehe oben Quote
raute4ever Posted October 19, 2011 Posted October 19, 2011 wie bekommt man denn diesen Fortschrittsbalken links neben dem programm im Neutrinocl hin? Bei mir ist da nix Quote
Stinkbärchen Posted October 20, 2011 Posted October 20, 2011 Hast du die Bilder aus Images\TimeLine kopiert? Quote
raute4ever Posted October 21, 2011 Posted October 21, 2011 jo, aber wohl in den falschen ordner, nämlich im skin in den images ordner. Jetzt geht es. Danke Quote
Kimins Posted November 15, 2011 Posted November 15, 2011 Can we have favorite channel number in favorites list as it is neutrinoCL? Quote
vitall10 Posted January 15, 2014 Posted January 15, 2014 tell me who works TVMAN in the skin x-skin mod 2.1I understand that the need for this file TVman.xml skin. Put your someone, please. Quote
mague Posted January 25, 2014 Posted January 25, 2014 A skin for TVman is available now. TVman is configurable. There is no Skin to do it all. This is an english Version of how i would do it. It uses EPG AutoSwitch. Download at the bottom of post #1 http://www.DVBViewer.tv/forum/topic/48834-tvman/ Quote
rodjd Posted July 6, 2016 Posted July 6, 2016 How I modify font too see full text in osd?I tried too modify font.xml but not succeed. Quote
rodjd Posted October 23, 2016 Posted October 23, 2016 (edited) work in 5.6.4 best OSD ! Edited October 23, 2016 by rodjd Quote
