hongkongrubbish Posted June 5, 2011 Posted June 5, 2011 (edited) Hi all, I am having a problem in scanning channels. When I opened up the Option panel, the hardware section said there was a hardware named LME_PCTV_MV5385. But when I opened the channel editor and scanned, it said No hardware Available. The situation is very similar to this post http://www.DVBViewer.tv/forum/topic/14196-no-hardware-available-no-channels-found/ but no solution was mentioned. I have spent a lot of time figuring it out but failed. Please help My DVB receiver: Mix Metal Mini OS: Win Server 2008 R2 MB: Foxconn G31M-Ssupport.zip Edited June 5, 2011 by hongkongrubbish Quote
Griga Posted June 5, 2011 Posted June 5, 2011 What about TransEdit? Does scanning work? If not, which error message do you get? Quote
hongkongrubbish Posted June 6, 2011 Author Posted June 6, 2011 Transedit said: Initializing the DVB device has failed. Performing a new hardware detection on Settings->Hardware may help. Quote
Griga Posted June 6, 2011 Posted June 6, 2011 TransEdit -> Settings -> Hardware -> tick "Use internal Network Provider filter". Does it change anything? Quote
hongkongrubbish Posted June 6, 2011 Author Posted June 6, 2011 TransEdit -> Settings -> Hardware -> tick "Use internal Network Provider filter". Does it change anything? Yes it changed! No more No hardware available now, but still no channels were found ... Quote
hongkongrubbish Posted June 6, 2011 Author Posted June 6, 2011 TransEdit -> Settings -> Hardware -> tick "Use internal Network Provider filter". Does it change anything? Griga, thank you!! After I clicked the "Blind scan", and return to DVBViewer and tick that box again in hardware, it all became OK! However, there is another question. 1) DVBViewer does not start playing itself. I have to switch a channel to start it playing. 2) I found that when I was watching HD channels, the hardware acceleration seems not working: CPU rises to 100% and have delayed piture. I am using HD4350, and H264 codec is ffdshow DXVA video decoder by Klite codec. What is the problem? Please see my attached supporting zip file support.zip Quote
