newOSD rc3
Guest Lars_MQ
I know a lot of updates the last few days, but I think this one is quite nice. Semitransparency in Overlaymode like the native DVBViewer OSD does it.
From now on there will only be bugfix releases, I think it's time for the 1.0.
In the meantime I will work on the skins ;)
You can download the plugin as always from the memberarea.
newOSD for DVBViewer
The newOSD plugin replaces the standard-OSD of the DVBViewer. It enhances the DVBViewer with a skinable Onscreendisplay and a interface to enable other plugins, to use the OSD easyly.
Version history
Version 0.9 RC3
Add: Semitransparency for graphical Elements (no picture or text). See Help -> ini-File for more information.
Fix: Display of gradient in progressbar was faulty.
Optimized: Defaultskin work with semitransparency
Add: TV-Logo to default skin
You can get the defaultskin by deleting the newOSD.ini or the line "Skin=" inside the file.
I also uploaded the extended Logopack, thanks to desasterman for it.
For now mostly german TV-Stations but hopefully we will extend it over time.
Have fun
lars
i have DVBViewer rc1 and newosd rc3 when i go to show epg doesn`t show me next program and timeline! when i use a normal osd it`s working great!
why?;)
Guest Lars_MQ
why?;)
When does that happen, if you select the EPG from then OSD-Menu?
Or if you try to click the Channelinfo (seen when switching channels)? Unfortunatly that doesn't work (for now) because of restrictions of the DVBViewer.
Which timeline do you mean? The graphical EPG-Overview for the OSD? Therefor you need the osdTimeline Plugin.
lars
i mean channelinfo:)
timeline when i switching channel i mean:)
keep good work:)
yes this doesn't work this time. The new OSD is this time not clickable ... so you cant switch between miniEPG and description of this film...
Guest Lars_MQ
Well as a workaround for now, you could assign the present and next EPG details to a key in the settings menu of DVBViewer. You can't click it, but pressing the apropriate key will show the infos.
lars
Edited by Lars_MQ
