How programming recording timers from RS 1.8.x.x
Hi everybody
Until RS 1.7.2.0 I have not problems for Timer my recordings all work fine. No fault.
From 1.8.x.x I dont know how I must programming my timers
With RS 1.7.2.0 I used add Internal task timer from Tag Timer with web interface and with all my Search EPG programs and all perfect. Now when I try to do same, it seems nothing happen.
Anybody can tell me when I am wrong
Another little thing is when from web interface I select Tag Programs, then appair a litle windows warning me than stopping a script program.... first time I see in RS.
Thanks in advance
You use IE? There is a problem with IE try chrome or firefox if possible... I'm working on it.
Yes, I use IE with XP Pro SP3
Thanks Lars, I´ll wait for your fix
May be next release?
Edited by defcon5
Inmediatly receive your answer Í installed Google chrome and the warning of script never more appaired but RS continue working irregulary, sometimes record timer sometimes not
Do you need any information or support file for diagnose my problem?
With versions before 1.8.x all is ok with autotimer
Thanks
Hi
Nobody have had a problem or issue after a updating of RS from 1.7.X to 1.8.x with timers using Autotimer ?
Thanks and waiting for a little clue
  • 4 weeks later...
Hi Lars
Is possible the problem has fixed with 1.9.0 and IE?
I´ve installed this version and the script warning is active
Cheers
