No livetv after a sleep lauched from "Standby" menu
Hi everyone!
I'm new over here...
I've been evaluating DVBViewer demo before purchasing and I've found that (in my computer ;) ) it doesn't restart livetv after a sleep if the sleep command is sent from within the DVBViewer menus (ie. System->Standby, Extended Exit->Standby or configured to do Standby on Exiting). After wake up it stays on black video screen but it correctly responds to input and will restart livetv if a channel is manually re-tuned.
Instead, it works OK (automatic relaunch of last tuned channel on wake up) when the sleep was initiated by the keyboard Sleep button or by the main Power button (configured to do sleep by the OS).
These are some excerpts from the logs,
When OK:
29.06.11 06:27:01.692 TfrmMain Release Pinnacle RoyalTS Tuner (1)
29.06.11 06:27:01.692 TfrmMain Destroy Pinnacle RoyalTS Tuner (1)
29.06.11 06:27:01.897 TfrmMain Destroyed Pinnacle RoyalTS Tuner (1)
29.06.11 06:27:01.898 TfrmMain hamDeleted Pinnacle RoyalTS Tuner (1)
29.06.11 06:27:01.904 Powermessage PBT_APMSTANDBY
29.06.11 06:27:18.359 SetThreadExecutionState 0x80000003
29.06.11 06:27:18.710 Powermessage PBT_APMRESUMEAUTOMATIC
29.06.11 06:27:18.711 Powermessage PBT_APMRESUMESTANDBY
29.06.11 06:27:18.711 Settuner Start
When no so OK:
29.06.11 06:31:50.719 TfrmMain Release Pinnacle RoyalTS Tuner (1)
29.06.11 06:31:50.719 TfrmMain Destroy Pinnacle RoyalTS Tuner (1)
29.06.11 06:31:50.924 TfrmMain Destroyed Pinnacle RoyalTS Tuner (1)
29.06.11 06:31:50.925 TfrmMain hamDeleted Pinnacle RoyalTS Tuner (1)
29.06.11 06:31:50.925 SetThreadExecutionState 0x80000000
29.06.11 06:32:28.138 Powermessage PBT_APMRESUMEAUTOMATIC
29.06.11 06:32:28.138 Powermessage PBT_APMRESUMESTANDBY
29.06.11 06:32:44.880 End App before OSD terminate
29.06.11 06:32:44.896 End App -----------------------------------
My testing setup is Win7 on a HP DC5750 + Radeon HD5750 + PCTV Dual DVB-T
If you need them I will post more details (maybe support.zip?) but for a start I would like to know if any of you observe this behaviour on your machines.
Thanks for reading!
I'm eager to resolve these little issues on my machine so I can buy this really great app that is DVBViewer.
