Auto timer or Auto Search
Is it possible to run the AutoTimer or AutoSearch Timer every hour ?
The problem is that for some provider i dont have a full egp program list, they send via egp only 3 titles.
Thank you
Not automatically, you have to make 24 Auto Search/EPG Update timer.
Ok, thank you for your answer.
How about using a TV grabber and import the results with XEPG...in that way you will get at least a full weeks EPG for all channels?
Edited by majstang
yes, i'm looking for that way right now :) .... i think that xmltv can solve my problem.
Edited by Reneg
Thank you majstang.
Now my EPG is grabbed using XMLTV and added to DVBVewer via XEPG.
But i have a problem with 1 channel.
RAI4 (Italy), is grabbed correctly and if i check the EPG using DVBViewer everything is right, but in Recording Service that EPG's Channel is empty.
Any Idea ?
DVBViewer is setted to import EPG via DVB Recording Service.
So, which grabber are you using?
If EPG in RS has an empty channel the one you see in DVBViewer client is an old EPG not updated yet from RS.
Are you sure this empty channel exist in the xmltv grabber output file? Please doublecheck it. Also to see if
EPG update works (all settings is made correct) from RS to DVBV you can delete the EPG.dat in DVBV config folder (CMUV-->DVBViewer),
not the EPG.dat in CMUV-->DVBViewer-->config folder though (that's the one for RS).
ADD:
When checking the xmltv output file it is not enough the channel missing from RS EPG are listed in the beginning of file...you have to check if any shows got scrubbed for this channel further down in the output file.
If you have show scrubbings for RAI4 and this channel is still missing from RS EPG then it's time to check the XEPG channel pairings...it's quite easy making misstakes here.
Last step is to get RS to DVBViewer update to work and for that you have the settings and update button on DVBV-->Options-->Recording Service tab. First press "test connection"...if successful the settings are correct. Then press "Update EPG".
Edited by majstang
I'm Using XMLTV to grab EPG (Last Version)
http://www.fileserve.com/file/kKAvcZV (XML FILE)
and Here a Screenshot:
XEPG LOG:
Xepg Version: 0.5.0.0 beta
IMPORT LOG
DESTINATION: Recording Service
Import Method: As XML Text
Processing: C:\Documents and Settings\All Users\Dati applicazioni\Xepg\Pairings.xml
840022968765998   www.alice.tv   [64511-5800-3630-1]
564316546014546   animalplanet.skytv.it   [318-12100-7506-1]
840023230910428   arturo.guidatv.sky.it   [64511-9800-4060-1]
564316369068044   news.bbc.co.uk   [318-9400-8204-1]
564118577741830   boing.guidatv.sky.it   [272-6000-6-1]
564118577741829   www.canale5.com   [272-6000-5-1]
845593224157145   canale51.guidatv.sky.it   [272-960-6105-2]
564316231434600   cartoonnetwork.mediasetpremium.mediaset.it   [318-7300-360-1]
840023217810628   deakids.skytv.it   [64511-9600-11460-1]
840022595222532   deakidspiu1.skytv.it   [64511-100-15364-1]
840023217810622   disneyinenglish.skytv.it   [64511-9600-11454-1]
564316152798142   eentertaiment.skytv.it   [318-6100-7102-1]
840023230910435   fantasy.skytv.it   [64511-9800-4067-1]
564316152798160   foxlife.skytv.it   [318-6100-7120-1]
840023165379814   www.foxnews.com   [64511-8800-9446-1]
563809064848932   frisbee.guidatv.sky.it   [200-1800-3620-1]
840022595222477   hiphoptv.skytv.it   [64511-100-15309-1]
564118577741828   iris.guidatv.sky.it   [272-6000-4-1]
845593224157146   italia11.guidatv.sky.it   [272-960-6106-2]
564316283877899   k2.guidatv.sky.it   [318-8100-14859-1]
840023217810626   la3.skytv.it   [64511-9600-11458-1]
564118577741831   la5.guidatv.sky.it   [272-6000-7-1]
840023211256887   www.la7.it   [64511-9500-11319-1]
844549517738601   www.la7d.it   [29-512-617-2]
840022968765999   www.leonardo.tv   [64511-5800-3631-1]
564316546014545   mgm.guidatv.sky.it   [318-12100-7505-1]
840022641083795   mtvclassic.guidatv.sky.it   [64511-800-1427-1]
840022641083797   mtvdance.guidatv.sky.it   [64511-800-1429-1]
840023211256965   mtvrocks.guidatv.sky.it   [64511-9500-11397-1]
840022641083796   mtvmusic.guidatv.sky.it   [64511-800-1428-1]
840022968766001   www.marcopolo.tv   [64511-5800-3633-1]
840022595222556   www.matchmusic.it   [64511-100-15388-1]
845593222844331   mediasetextra.guidatv.sky.it   [272-940-4011-2]
840023211256872   mydeejay.guidatv.sky.it   [64511-9500-11304-1]
840022962213129   nategomusic.skylife.it   [64511-5700-4361-1]
564316231434595   natgeowild.skylife.it   [318-7300-355-1]
564316093812050   rai5.guidatv.sky.it   [318-5200-3410-1]
564316106919150   raigulp.rai.it   [318-5400-3310-1]
564316565676342   raimovie.rai.it   [318-12400-8502-1]
564316106919146   raipremium.guidatv.sky.it   [318-5400-3306-1]
564316093812046   raiscuola.rai.it   [318-5200-3406-1]
564316106919145   raisport1.guidatv.sky.it   [318-5400-3305-1]
564316106919141   raisport2.guidatv.sky.it   [318-5400-3301-1]
564316106919147   raistoria.rai.it   [318-5400-3307-1]
564316093812070   raiyoyo.guidatv.sky.it   [318-5200-3430-1]
845790730068373   rai5.rai.it   [318-5-8597-2]
845790729871729   raisport1.rai.it   [318-2-8561-2]
845790729871730   raisport2.rai.it   [318-2-8562-2]
844549518000172   rt.discovery-italia.com   [29-516-44-2]
845593224157144   rete41.guidatv.sky.it   [272-960-6104-2]
840022595222501   www.rocktv.it   [64511-100-15333-1]
840023165379813   www.skynews.it   [64511-8800-9445-1]
840022962213100   tg24eventi.guidatv.sky.it   [64511-5700-4332-1]
840022962213096   tg24primopiano.guidatv.sky.it   [64511-5700-4328-1]
840022962213098   tg24rassegne.guidatv.sky.it   [64511-5700-4330-1]
840023217810588   toondisneypiu1.skytv.it   [64511-9600-11420-1]
840023211256883   www.videoitalia.it   [64511-9500-11315-1]
840023165379842   yachtandsail.skylife.it   [64511-8800-9474-1]
845593220546706   iris.mediaset.it   [272-905-146-2]
840022641083811   www.axn.it   [64511-800-1443-1]
840022641083793   piuuno.axn.it   [64511-800-1425-1]
840023211256878   babytv.guidatv.sky.it   [64511-9500-11310-1]
840022595222535   boomerang.cartoonnetwork.it   [64511-100-15367-1]
840023021202278   cielo.guidatv.sky.it   [64511-6600-11110-1]
840023211256886   paramountcomedy.skytv.it   [64511-9500-11318-1]
840023001538505   cultcni.skytv.it   [64511-6300-8137-1]
845593220218989   disney.mediasetpremium.mediaset.it   [272-900-109-2]
840023021202286   www.disneychannel.it   [64511-6600-11118-1]
845593220284576   piu1.disneychannel.it   [272-901-160-2]
840022595222469   disneyjunior.guidatv.sky.it   [64511-100-15301-1]
840022595222475   disneyxd.guidatv.sky.it   [64511-100-15307-1]
840023217810621   disneyxd1.guidatv.sky.it   [64511-9600-11453-1]
840023165379844   dovetv.skytv.it   [64511-8800-9476-1]
840023165379778   easybaby.guidatv.sky.it   [64511-8800-9410-1]
840023001538504   foxretro.guidatv.sky.it   [64511-6300-8136-1]
840022968766003   fox.skytv.it   [64511-5800-3635-1]
840023230910421   fox2.guidatv.sky.it   [64511-9800-4053-1]
840023001538507   foxcrime.skytv.it   [64511-6300-8139-1]
840023001538509   foxcrimepiu1.skytv.it   [64511-6300-8141-1]
840023230910423   foxcrime2.guidatv.sky.it   [64511-9800-4055-1]
840023230910422   foxlife2.guidatv.sky.it   [64511-9800-4054-1]
840023034309581   gxt.skytv.it   [64511-6800-11213-1]
840023001538508   gamberorosso.guidatv.sky.it   [64511-6300-8140-1]
845593220284572   hiro.mediasetpremium.mediaset.it   [272-901-156-2]
564118577741825   www.italia1.com   [272-6000-1-1]
840023165379838   jimjam.skytv.it   [64511-8800-9470-1]
845593220218991   joi.mediasetpremium.mediaset.it   [272-900-111-2]
845593223500991   joi1.mediasetpremium.mediaset.it   [272-950-5311-2]
840022641083807   ladychannel.guidatv.sky.it   [64511-800-1439-1]
840023165379791   lei.skytv.it   [64511-8800-9423-1]
840023165379847   manga.skytv.it   [64511-8800-9479-1]
845593220218992   mya.mediasetpremium.mediaset.it   [272-900-112-2]
845593223500992   mya1.mediasetpremium.mediaset.it   [272-950-5312-2]
840022968766009   www.ngcitalia.it   [64511-5800-3641-1]
840023230910426   piu1.ngcitalia.it   [64511-9800-4058-1]
840023211256888   nickelodeon.skytv.it   [64511-9500-11320-1]
845790730002821   premium.raisat.it   [318-4-8581-2]
564316565676351   rai1.rai.it   [318-12400-8511-1]
564316565676352   www.raidue.rai.it   [318-12400-8512-1]
564316565676353   www.raitre.rai.it   [318-12400-8513-1]
564118577741827   www.rete4.com   [272-6000-3-1]
840022962213130   skytg24.skytv.it   [64511-5700-4362-1]
840023027756486   skyuno.skytv.it   [64511-6700-11718-1]
840023021202288   skyunopiuuno.skytv.it   [64511-6600-11120-1]
845593220218998   studiouniversal.mediasetpremium.mediaset.it   [272-900-118-2]
840023021202280   toondisney.skytv.it   [64511-6600-11112-1]
840023027756505   wimbledon1.guidatv.sky.it   [64511-6700-11737-1]
840023230910419   youme.guidatv.sky.it   [64511-9800-4051-1]
845790730002822   yoyo.raisat.it   [318-4-8582-2]
840023217810589   deasuper.skytv.it   [64511-9600-11421-1]
564316565676356   www.rainews24.rai.it   [318-12400-8516-1]
845593220546705   www.boingtv.it   [272-905-145-2]
840023211256963   www.mtv.it   [64511-9500-11395-1]
845593220546701   canale5dtt.guidatv.sky.it   [272-905-141-2]
840022962213131   current.it   [64511-5700-4363-1]
845593223500981   disney1.mediasetpremium.mediaset.it   [272-950-5301-2]
840023230910425   piu1.thehistorychannel.co.uk   [64511-9800-4057-1]
840023001538511   www.thehistorychannel.co.uk   [64511-6300-8143-1]
840023001538489   natgeoadventure.skytv.it   [64511-6300-8121-1]
845790729801033   rai1dtt.guidatv.sky.it   [318-1-3401-2]
845790729801034   rai2dtt.guidatv.sky.it   [318-1-3402-2]
840023250578736   realtime1.guidatv.sky.it   [64511-10100-11568-1]
845593220546703   rete4dtt.guidatv.sky.it   [272-905-143-2]
840023021202269   skycinemapiu1.skytv.it   [64511-6600-11101-1]
840023021202275   skycinemapiu24.skytv.it   [64511-6600-11107-1]
840023211256868   skycinema1.skytv.it   [64511-9500-11300-1]
840023021202277   skycinemaclassics.skytv.it   [64511-6600-11109-1]
840023027756493   skycinemacomedy.guidatv.sky.it   [64511-6700-11725-1]
840023021202273   skycinemafamily.skytv.it   [64511-6600-11105-1]
840023027756492   skycinemahits.skytv.it   [64511-6700-11724-1]
840023021202283   skycinemamax.skytv.it   [64511-6600-11115-1]
840023027756483   skymaxpiu1.skytv.it   [64511-6700-11715-1]
840023021202291   skycinemapassion.guidatv.sky.it   [64511-6600-11123-1]
840022962213089   skytg24meteo.skytv.it   [64511-5700-4321-1]
564315792360641   weddingtv.guidatv.sky.it   [318-600-17601-1]
840022968766003   foxpiuuno.skylife.it   [64511-5800-3635-1]
564118577741825   italia1dtt.guidatv.sky.it   [272-6000-1-1]
845593220546702   italia1dtt.guidatv.sky.it   [272-905-142-2]
845593222844326   italia1dtt.guidatv.sky.it   [272-940-4006-2]
845593224157346   italia1dtt.guidatv.sky.it   [272-960-6306-2]
564316565676353   rai3dtt.guidatv.sky.it   [318-12400-8513-1]
564316565676351   www.raiuno.rai.it   [318-12400-8511-1]
845790729801033   www.raiuno.rai.it   [318-1-3401-2]
845790730068373   rai5.guidatv.sky.it   [318-5-8597-2]
845790730002824   raigulp.rai.it   [318-4-8584-2]
845790729801033   rai1.rai.it   [318-1-3401-2]
845790729801034   www.raidue.rai.it   [318-1-3402-2]
845790729801035   www.raitre.rai.it   [318-1-3403-2]
845790729801035   rai3dtt.guidatv.sky.it   [318-1-3403-2]
845790730002825   raimovie.rai.it   [318-4-8585-2]
845790729801043   www.rainews24.rai.it   [318-1-3411-2]
845790730002821   raipremium.guidatv.sky.it   [318-4-8581-2]
845790729871729   raiscuola.rai.it   [318-2-8561-2]
845790729871730   raisport2.guidatv.sky.it   [318-2-8562-2]
845790730002822   raiyoyo.guidatv.sky.it   [318-4-8582-2]
845790730002823   rai4.raisat.it   [318-4-8583-2]
Get status code: 200
GET: http://admin@127.0.0.1:8090/
GET RESULT: <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Frameset//EN" "http://www.w3.org/TR/html4/frameset.dtd">
<html>
<head>
<title>DVBViewer Media Server 1.8.0.1 (SVR2)</title>
<meta http-equiv="content-type" content="text/html;charset=UTF-8">
   <meta http-equiv="expires" content="0">
<meta http-equiv="Pragma" content="no-cache">
<meta http-equiv="cache-control" content="no-cache">
<link rel="shortcut icon" type="image/png" href="recservice.png">
</head>
<frameset rows='68,*' border='0' >
<frame name='top' scrolling='no' src='top.html' noresize='noresize' frameborder='0'>
   <frame name="main" noresize src="epg_listnew.html?aktion=epg_listnew">
<noframes>
	<body>
		<p>Your browser doesn't support Frames!</p>
	</body>
</noframes>
</frameset>
</html>
GET STATUS: <?xml version="1.0" encoding="utf-8" ?><status><recordcount>0</recordcount><clientcount>1</clientcount><epgudate>0</epgudate><epgbefore>5</epgbefore><epgafter>10</epgafter><timezone>120</timezone><defafterrecord>0</defafterrecord><recfolders><folder size="122935001088" free="120200073216">E:\Registrazione SAT</folder></recfolders></status>
GET VERSION: <?xml version="1.0" encoding="utf-8" ?><version>DVBViewer Recording Service 1.8.0.1 (SVR2)</version>
GET: http://admin@127.0.0.1:8090/?epg_clear=
GET RESULT:
Old EPG deleted
Charset = 255
Processing: E:\Xmltv\egp.xml
XMLTV reader Engine: EasyXML SAX
xml version="1.0" encoding="ISO-8859-1"
--------------Statistics----------------------
Nodes crawled: 11254
Missing Channel IDs: 0
Missing Or Invalid Stop Times: 1363
Missing Or Invalid Start Times: 0
Chunks Sent: 10
Paired <programme> items found: 9817
Depth 2 Nodes crawled: 50463
Depth 3 Nodes crawled: 254
Success!
In Rai4, u can see few EPG data (Not grabbed, but sent via DDT when Tuned to RAI4) But i want update that channel via XMLTV so i can have EPG for 1 week.
Other channel as RAI2 or Sky Italia are working as well.
Edited by Reneg
Assessing from your postings it seem you got the XEPG parings for RAI4 correct. Then you have to focus on your grabber and the output it produces. As it seem to be now, you only have the provider EPG for RAI4...which means XMLTV does not grab anything for RAI4.
When checking the xmltv output file it is not enough if the channel missing from RS EPG are listed in the beginning of file...you have to check if any shows got scrubbed for this channel further down in the output file.
U mean the XML I got from the grabber right ?
<programme start="20110708063500 +0200" channel="rai4.raisat.it">
   <title lang="it">Streghe</title>
   <sub-title lang="it">Stagione 5 Episodio 9 - Mi chiamo Sam</sub-title>
   <episode-num system="onscreen">Stagione 5 Episodio 9</episode-num>
   <episode-num system="xmltv_ns">4.8.0/1</episode-num>
 </programme>
 <programme start="20110708072000 +0200" channel="rai4.raisat.it">
   <title lang="it">Beverly Hills 90210 IX 'Guai per tutti'</title>
   <sub-title lang="it">Episodio 12</sub-title>
   <episode-num system="onscreen">Episodio 12</episode-num>
   <episode-num system="xmltv_ns">.11.0/1</episode-num>
 </programme>
 <programme start="20110708080500 +0200" channel="rai4.raisat.it">
   <title lang="it">Watch Over Me</title>
   <sub-title lang="it">Episodio 49</sub-title>
   <episode-num system="onscreen">Episodio 49</episode-num>
   <episode-num system="xmltv_ns">.48.0/1</episode-num>
 </programme>
 <programme start="20110708084000 +0200" channel="rai4.raisat.it">
   <title lang="it">Being Erica</title>
   <sub-title lang="it">Stagione 3 Episodio 6</sub-title>
   <episode-num system="onscreen">Stagione 3 Episodio 6</episode-num>
   <episode-num system="xmltv_ns">2.5.0/1</episode-num>
 </programme>
Edited by Reneg
Yes, exactly!
How many days of grabbings do you have for RAI4?
3 days , and i've created XML file few minutes ago.
As you can see in the xml , seem that Rai4 is grabbed..
Edited by Reneg
Hmm..this is a hard one for sure! If you have other channels working when importing the .xml in to RS EPG then you must have the connection settings in XEPG-->Options-->Recording Service tab correct. Maybe if you inactivate the XEPG-->Options-->General-->Delete old EPG prior to import, things could go better. This option have been causing trouble before, but not for single channels as far as i know.
Also, there could be a good idea asking about this issue in the XEPG thread if you don't find any solution.
ADD:
When things like this happens for me i usually Unpair all channels in XEPG and saves it and close XEPG. Restart and redo the channel pairings again and applies it. Important to have the latest .xml file already done with the latest channellist. If doing any changes in the XMLTV grabber channellist the old pairings in XEPG can fail.
Edited by majstang
Can you make a screen dump of the RS task you are using for grab and import of EPG?
Tryed to delete EPG.DAT RS and DVBV.
Unpaired all Channel (apply - exit)
Paired only RAI4 (Just to try), Applied and started RS again.
No EPG IMPORTED but the file EPG.dat has been re-created (300kb for rai4 EPG)
Edited by Reneg
C:\Programmi\Xepg\Xepg.exe" -xGrabThenImport
But now, trying to fix the issue, im using TEST IMPORT in XEPG.
maybe a bug in XMLTV RAI4 Script ? and the XML created is not compatible ?
If deleting EPG.dat for RS manually and then doing the grab/import i often have to stop service and restart it to make the new EPG.dat to stick. Avoid deleting it manually if you can. RS will give you trouble when doing that.
For the RS EPG update task:
Try C:\Programmi\Xepg\Xepg.exe without the " in Filename box.
In Parameters box use -xGrabThenImport
No, i don't think so! The format of the grabbings you have showed me so far is correct. You can always try using WebGrab++ instead (this software automatically runs in hidden mode if executed from an RS task), but it is more likely this issue is settings related in either RS or XEPG.
Here is a log of XEPG with 1 Working Channel
Nodes crawled: 181
Missing Or Invalid Stop Times: 91
Chunks Sent: 1
Paired <programme> items found: 90
Depth 2 Nodes crawled: 865
Depth 3 Nodes crawled: 0
Success!
Here is a Log of EPG with RAI4.
Nodes crawled: 181
Chunks Sent: 0
Paired <programme> items found: 0
Success!
Paired ITEMS FOUND: 0
Here is the XML file containing RAI4 and AXN (Working one)
 <programme start="20110710051500 +0200" channel="rai4.raisat.it">
   <title lang="it">STINGERS</title>
   <sub-title lang="it">Stagione 6 Episodio 2</sub-title>
   <episode-num system="onscreen">Stagione 6 Episodio 2</episode-num>
   <episode-num system="xmltv_ns">5.1.0/1</episode-num>
 </programme>
 <programme start="20110709005000 +0200" stop="20110709014000 +0200" channel="www.axn.it">
   <title lang="it">Most Shocking</title>
   <sub-title lang="it">Episodio 5</sub-title>
   <desc lang="it">Continuano le...</desc>
   <category lang="it">show</category>
   <category lang="it">intrattenimento</category>
   <episode-num system="onscreen">Episodio 5</episode-num>
   <episode-num system="xmltv_ns">.4.0/1</episode-num>
 </programme>
Edited by Reneg
There is no STOP time..... maybe is that the issue ?
Yes, it can be! I don't know how it works in detail for RS EPG.dat and the exact format it requires, but maybe it can't handle when starttime for the next show is the stoptime for the previous show. Good spotting...i didn't see it :blush:
Try WebGrab++ just to see what happens :)
WebGrab++ support italian providers ?
thank you again :)
I let u know ^^
ok, using WEBGRAB++ i can add RAI4 EPG without any problem..
Thank you Majstang :)
Now i'll study how to set this new grabber :)
