Can't play .MP4
themaster1
I have reinstalled XP and currently am fine tuning everything, it seems i can't play .mp4 for some odd reason( mkv etc.. no problem).I don't recall having this problem on my previous Xp, anyone came across this problem and found a solution ? I'd be glad to read it.
I have all the right codecs (cyberlink, coreavc) for AVC/H264, MPC and PDVD can play them just fine so the problem lies in DVBViewer i believe so i'm clueless really as i type
Edited by themaster1
That's not enough. You need a Demultiplexer/Splitter DirectShow filter that "understands" the MP4 format. The Haali Splitter does this job pretty well. Make sure to enable .mp4 handling on installation.
Like always :rolleyes: No idea what's going on? Things are getting too complicated? Blame the frontend, and you'll feel better... :)
It seems you were right i had an old Haali Media splitter release that didn't take .mp4's, now everything is fine, sorry for the troubles really.
