Digital Devices Cine S2 V6 DiSEqC 1.1?
boborg
I have just replaced a Floppy DVB-S2 with a Digital Devices Cine S2 V6. I have a DISEqC 1.1 EMP Centauri which worked fine with delay 150 and uncomitted for the LNB's. The Digital Devices Cine S2 V6 does not work with this. Only Uncomitted 1 seems to be pretty stable. When switching to others mostly no signal.
I have tried experimenting with delay value but not had any succes? Any ideas to what I could try next?
Edited by boborg
Thanks for the reply. Sadly this did not fix the switching issue. It works some times but say I go from 28,2 east channel to 13 East channel and then back to the same 28,2 east channel it does not work.
I switched with a Satconn X10 or something like that DiSEqC switch. Seems to work after playing around a bit with delay.
Edited by boborg
