lines and judder
wazza_2
wonder if ya can help me , On DVBViewer i am getting some lag and sometimes lines through the screen, when i install hd pack 2.6 it says (msdt.exe -id AeroDiagnostic) error do ya no what i have to do to fix this, i am running a radeon 5770 HD graphics card 12gig memory ssd harddrive and a phenom II x4 3.1 so i cant see what the problem is
A good thumb rule is stay far away from all codec packs. They can mess up your system quite bad. Only install the codecs you need one by one.
ok done that think i have sorted that problem out , the only thing is that i am having to keep rebiulding my graphics if i do anything, as i am using a quad core processor is they anyway i can set it so it only uses 1 core
  • 1 month later...
First thing, be sure that DXVA is enabled.
Use PowerDVD as codec.
But first, switch back to the restorepoint where you installed HDpack.
The codec can run on a diffferent thread.
Otherwise post a support.zip file
i also use hd pack and klite, no problem here.
Start DVBViewer, right click on window, go to Viewe-Filters, and see what codec you have here.
If for example is DivX, change it to something else from : View-Options-DirectX, change here your mpeg 2 codec and your hd codec to something else.
If your codec is Cyberlink, you see that in View-Filters, click on Cyberlink codec here, and activate DXVA, then rebuilt graph.
