android app. remote
Hello
Hi:)
Just for information:
I felt over this app. for Android phones, turns your Android phone into a full working remote.
https://market.android.com/details?id=com.Relmtech.RemotePaid&feature=search_result
And special DVBViewer remote to download, in this topic in the Unified Remote forum:
http://forum.unifiedremote.com/viewtopic.php?f=50&t=824
it works, please read the entire topic before installation!!, it's not a free app. but worth the little money to my opinion.
And just for information, I am not the author, or involved in any way, in that project so this is not a commercial to sell it!!, I just think it is smart!!
I can see it has been discussed in the German forum earlier, but before the latest versions especially for DVBViewer.
  • 1 year later...
I'm searching a DVBViewer plugin for Unified Remote. Your like is down and I couldn't find another link. Do you know where to get it?
VERY sorry for late answer.. I had not seen your post until now.
Well it looks like unified remote is still working
http://support.unifiedremote.com/
but.. the remote for dvbv. I got from a person that wrote it and published it for download on Unified Remotes board, but they have closed the board, and answer only support tickets , and can't help with remotes developed by others.
All they have send me is an e-mail address to the person that made the DVBViewer remote.
info@styletronix.net
I have not written to him yet. I have not used the remote for a long time, and the other day I installed it again, or tried I should say, and it is not working anymore.
I will send him a mail today, if I get a usable answer I will let you know.
By the way, take a look at this app.:
http://code.google.com/p/DVBViewer-controller/
There is a remote in that also !!
you can read about it here:
http://www.DVBViewer.tv/forum/topic/51730-direct-streaming-hd-live-tv-to-nexus-10/
a good idea to read the entire tread !!
Edited by krasno
Thanks for your reply.
I'll have a look at DVBViewer Controller these days.
Hello guys, i was looking for the Unified Remote's plugin (i'm updating to Win8), but luckily i found the DVBViewer custom remote on the second computer and i'm going to share it with you :)
If you don't remember, you need to put the folder here: Unified Remote\Remotes\Custom and you should uncheck the "start with windows" option (it doesn't work without it). You can add Unified Remote manually to Autostart folder.
http://www74.zippyshare.com/v/61314791/file.html
Have you refresh and select it in Remotes bookmark?
Edited by Przemek211
  • 4 months later...
It looks like all is working fine except PAUSE while playing TV, time-shift is on, don't know anything about programming so don't know what can be wrong... otherwise other options are working fine... tx for sharing.
Edited by RAGman7
  • 1 year later...
Can someone please re-upload the file above?, I've searched the net but I haven't been able to find it anywhere.
Thanks.
Thanks, I'll give it a try. Anyway, I asked for the Universal Remote custom remote because I'm already using that app as a general purpose HTPC remote controller and in my case will be more convenient since I only want to be able to switch channels and control volume.
  • 9 months later...
