CupawnTae Posted September 19, 2011 Posted September 19, 2011 Is %name a standard/supported variable for a file naming scheme? I don't see it listed on the wiki page but it seems to work for me. I just wanted to be sure it isn't a secret/hidden/unsupported feature that might disappear in a future release. (My use case is I'm adding timers via the http api and including episode number info in the event name, but if I record using %event in the pattern it takes the programme name from the EPG instead of the name I provided and the episode number is not available in the EPG. I just tried %name instead of %event to see what would happen and was very pleased to see it did exactly what I wanted).
barrygreybeard Posted September 21, 2011 Posted September 21, 2011 Is %name a standard/supported variable for a file naming scheme? I don't see it listed on the wiki page but it seems to work for me. I just wanted to be sure it isn't a secret/hidden/unsupported feature that might disappear in a future release. (My use case is I'm adding timers via the http api and including episode number info in the event name, but if I record using %event in the pattern it takes the programme name from the EPG instead of the name I provided and the episode number is not available in the EPG. I just tried %name instead of %event to see what would happen and was very pleased to see it did exactly what I wanted). Yes you're right. It appears that whatever you enter into the name field of a timer can be inserted in the name scheme by using %name. It doesn't appear to be mentioned anywhere though Barry
CupawnTae Posted September 21, 2011 Author Posted September 21, 2011 Thanks for the confirmation Barry. I guess the real question is can it be relied upon to stay that way...
barrygreybeard Posted September 21, 2011 Posted September 21, 2011 Unless the "powers that be" confirm this as a feature we can only hope as I find it useful, inserting episode numbers manually for example as you mentioned.
