IanSav Posted September 22, 2011 Posted September 22, 2011 Dear Griga, I just updated TransEdit to the new 3.8.1.0 English release. Would it be possible for you to update the pop up and context menus to use the English keyboard names for the shortcuts. Does "Strg" mean "Ctrl" and "Umsch" mean "Shift"? I haven't noticed any other translation issues as yet but I am still exploring and leaning this program. Regards, Ian. Quote
Griga Posted September 22, 2011 Posted September 22, 2011 Does "Strg" mean "Ctrl" and "Umsch" mean "Shift"? Yes. Caused by the localized German version of the Delphi development environment. There is no TransEdit localization, UI elements are not translated. The UI is supposed to be English throughout. I will look after it. Quote
Antonio Posted September 22, 2011 Posted September 22, 2011 Hi!!! Griga it is possible to make translation to TransEdit? As in DVBViewer a file *.lng Excuse for my English. Greetings from Russia Quote
Griga Posted September 22, 2011 Posted September 22, 2011 Much work. Also for users, who must make all the language files (except German). Quote
IanSav Posted September 22, 2011 Author Posted September 22, 2011 Hi Griga, Yes. Caused by the localized German version of the Delphi development environment. There is no TransEdit localization, UI elements are not translated. The UI is supposed to be English throughout. I will look after it. Thank you, in advance, for any updates and corrections you can make. If I find anything else I will let you know. Regards, Ian. Quote
IanSav Posted November 28, 2011 Author Posted November 28, 2011 Hi Griga, Thank you for fixing this in TransEdit 3.8.2.0. Regards, Ian. Quote
