BBC Channel Updates
glyn1972
Anyone got any idea which fequencies to scan? Since the BBC page yields nothing of any use what-so-ever, and I'd rather not spend an hour doing a full scan for 3 rarely used channels (BBC News is affected too).
Cheers
Steven
Use TransEdit 3.8 for a full scan (download from the members area, store TransEdit.exe it in the DVBViewer installation folder, where DVBViewer.exe is). Make sure that you are using an up-to-date transponder list for Astra 28° East (included in the TransEdit zip, must be stored in the DVBViewer configuration folder \ transponders subdirectory).
After a full scan the Scanner Window shows which (new) channels are not contained in the DVBViewer channel list yet (white background). Click the name column title to sort the channels by name, so that it gets easier to find and check a particular channel. Additionally open the Dead Channels Window. It shows which channels in the DVBViewer channellist cannot be found anymore (due to a frequency change or whatever) and allows to delete them.
This will give you an overview about what happened.
I will append the known DSat numbers to the Astra 28° East transponder descriptions, so it gets easier next time... "BSkyB" for almost all of them is boring anyway :)
