dolehaj Posted September 24, 2011 Posted September 24, 2011 Hi, I found out that even DVBV version 4.9.0.0 didn't solve problem with missing possibility of switching off the LNB. Is there any chance to add this option for TT-S3200/SS HD PCI card with BDA driver? I'm using w7 x64 and my tt driver version is 5.0.3.5. I'm using Moteck V-BOX II for my big dish to prevent problems with high current for an actuator. But this device is still on while the power for LNB is present and I couldn't turn it off by hand or remote. Currently I have to use a simple trick - disable and then enable (reinitialize) card driver in device manager to switch the LNB power off after shutting down the main program. I'm sure there must be a method to reinicialize a driver programmaticaly during shutdown of DVBV. However, everything else seems to work properly, thanks. Quote
Antonio Posted September 24, 2011 Posted September 24, 2011 (edited) +100 I too would like this function, but programmers don't hasten to include it in updating. Many programs supports such function. for example by CrazyCat69: just make 'fake' tune request with polarization=BDA_POLARISATION_NOT_DEFINED generic method, like technotrend, tevii and many other BDA drivers. Edited September 24, 2011 by Antonio Quote
CiNcH Posted September 25, 2011 Posted September 25, 2011 I have recognized and reported this issue to TechnoTrend some years back. LNB voltage is switched off for the S2-3200 when the driver is loaded and switched on when the BDA device is initialized, but not switched off again when the BDA graph is torn down. In the TT SDK it is not defined to execute a 'BDA_POLARISATION_NOT_DEFINED' tune request to switch off LNB voltage. And it is also not a common practice. Quote
dolehaj Posted September 25, 2011 Author Posted September 25, 2011 It's just what I was asking about - is it possible to reload device driver after BDA graph is already down? I know it's not a standard solution but who cares while it's working. At least until tt developers have finally realized that features like ON and OFF are quite usefull for every device. I would say even basic. Quote
Derrick Posted September 25, 2011 Posted September 25, 2011 In the TT SDK it is not defined to execute a 'BDA_POLARISATION_NOT_DEFINED' tune request to switch off LNB voltage. ..why not give it a try, if somebody who is not the least expert in the field says that it works? Can't cause too much damage Quote
Antonio Posted September 25, 2011 Posted September 25, 2011 All who wants can test this method on the devices (BDA_POLARISATION_NOT_DEFINED) run BLScan.exe from archive This function LNBPwrOff=1 in StreamReader.ini It works on Omicom, Technotrend, Tevii and other BDA... LNBPowerOff.rar Quote
Griga Posted September 25, 2011 Posted September 25, 2011 (edited) The same idea came to my mind this morning I'd recommend to test the attached commandline tool, because if it works, the code will most likely also work in DVBViewer, and we can use it in future releases. Basically BDA_LNB_Off.exe uses the same method as Antonio's tool (setting BDA_POLARISATION_NOT_DEFINED as polarisation), but provides the following commandline options for selecting the DVB-S device: No commandline parameters: The first BDA DVB-S device listed in the DVBViewer hardware options is used. DVB-C/T devices are ignored. -n, where n is a number (1, 2, 3...): The first, second, third... of the BDA DVB-S devices listed in the DVBViewer hardware options is used. "Name": The name of the DVB-S device (as displayed in the DVBViewer hardware options) that shall be used. The quotations marks are mandatory if the name contains blanks! Devices with different names are ignored. "Name" -n: The n'th device with the specified name is used. Example: BDA_LNB_Off.exe "TechnoTrend BDA/DVB-S Tuner" -2 will (hopefully) switch the LNB power of the second of two TechnoTrend DVB-S/S2 devices off. If an error occurs (no matching device found, initialization failed etc.) you will hear a message beep. BDA_LNB_Off.zip Edited February 17, 2013 by Griga Attachment replaced by a fixed version Quote
Antonio Posted September 25, 2011 Posted September 25, 2011 Griga No commandline parameters:... It doesn't work BDA_LNB_Off.exe "OMICOM S2 PCI" -1 So too doesn't work Doesn't switch off power LNB.. Quote
dolehaj Posted September 25, 2011 Author Posted September 25, 2011 Guys, for me both utils WORK! BDA_LNB_Off.exe without and also with parameter. I can see a small light at the end of the tunnel... Quote
HaraldL Posted September 25, 2011 Posted September 25, 2011 I'm interested too but have a noob question first: How do I see if LNB power is switched off or not? I cannot access the Multiswitch I'm connected to if it has to be checked there. Quote
Antonio Posted September 25, 2011 Posted September 25, 2011 (edited) Griga Your utility good works with Omicom S2 pci rev3. The problem was at me. Gud Edited September 25, 2011 by Antonio Quote
Griga Posted September 25, 2011 Posted September 25, 2011 How do I see if LNB power is switched off or not? By disconnecting the antenna cable and using a multimeter for measuring the voltage. But be careful - don't short-circuit the inner conductor and the shielding (in case the LNB power has not been switched off)! Guys, for me both utils WORK! BDA_LNB_Off.exe without and also with parameter. Ok, so we can implement this LNB power off method for OMICOM S2 and TT 3200 cards. Feedback about other cards is welcome! Quote
Antonio Posted February 16, 2013 Posted February 16, 2013 I noticed that my second DVB card is not switch off power. Only the first in the list. I use this command.cmd: BDA_LNB_Off.exe "OMICOM S2 PCI" -1 BDA_LNB_Off.exe "OMICOM S2 PCI" -2 Probably identical name of the DVB device leads to this result??? Quote
Griga Posted February 17, 2013 Posted February 17, 2013 Please attach a TransEdit.ini that shows how and in which order your devices are detected. Quote
Antonio Posted February 17, 2013 Posted February 17, 2013 I attach this file. In TransEdit LNB off voltage works on both cards, by virtue of LNBOff.0=1 and LNBOff.1=1 in config. But for me the command line utility BDA_LNB_Off.exe would be more convenient. TransEdit.ini Quote
Griga Posted February 17, 2013 Posted February 17, 2013 I can't figure out what's going wrong. Probably identical name of the DVB device leads to this result??? I don't think so. Your command clearly says "use the second one with this name", so the first one should be skipped. What does the -2 command do? Nothing at all? Or again LNB power off with the first device? What happens if you perform the -1 and -2 commands separately / manually? You can also try without names, just -1 and -2, because there are only two DVB-S devices in your PC. Quote
Antonio Posted February 17, 2013 Posted February 17, 2013 (edited) What does the -2 command do? Nothing at all? Or again LNB power off with the first device? command: BDA_LNB_Off.exe "OMICOM S2 PCI" -2 -LNB off on the first device only. command: BDA_LNB_Off.exe "OMICOM S2 PCI" -1 -LNB off on the first device only. You can also try without names, just -1 and -2 command: BDA_LNB_Off.exe -1 BDA_LNB_Off.exe -2 -LNB off on both devices. it is Ok. I did not know that without names so too is possible. Thanks. Edited February 17, 2013 by Antonio Quote
Griga Posted February 17, 2013 Posted February 17, 2013 Ok, I found the bug. The tool only evaluated the first commandline parameter. Hard to see: ParamStr(1) was supposed to be ParamStr(i) I've replaced the attachment above by a fixed version. Quote
Antonio Posted February 17, 2013 Posted February 17, 2013 Fixed version well. Both commands work now. With the name of devices and without a name. BDA_LNB_Off.exe "OMICOM S2 PCI" -1 BDA_LNB_Off.exe "OMICOM S2 PCI" -2 or BDA_LNB_Off.exe -1 BDA_LNB_Off.exe -2 Quote
