rdg Posted October 23, 2011 Share Posted October 23, 2011 (edited) Sometimes the operation of DVBViewer does not make sense... Record mode - DVBViewer OSD displays "2 Record" to stop recording, simply write "2 Stop Record". - When I change channels, OSD displays "No hardware available". Easier to say "Recording in progress, you can not change the channel." Edited October 23, 2011 by rdg Quote Link to comment
rdg Posted October 23, 2011 Author Share Posted October 23, 2011 - Automatic update RSS feeds with OSD notification Quote Link to comment
rdg Posted October 23, 2011 Author Share Posted October 23, 2011 If DVBViewer starts after HTTPServer, the webinterface shows "DVBViewer IS NOT active!" bug? Quote Link to comment
rdg Posted October 23, 2011 Author Share Posted October 23, 2011 - "Back" button in the OSD to display the previous menu (for My Music, My Videos, etc.). - In My Music, add a mini player OSD to see the track play - Bad translation to clear the playlist Quote Link to comment
bogdan1980 Posted October 24, 2011 Share Posted October 24, 2011 HTTPServer is obsolete, use DVBViewer rec service. HTTPServer is not working with latest vlc also. Quote Link to comment
rdg Posted October 24, 2011 Author Share Posted October 24, 2011 ok, but HTTPServer works with favorite channels. In Rec Service there is no web remote control. I do not understand the difference between Rec Service <=> DVBServer <=> webinterface. It's better to use Rec Service with DVBViewer Unicast or only DVBViewer? Quote Link to comment
bogdan1980 Posted October 25, 2011 Share Posted October 25, 2011 rec service is newer then httpserver, it has many options compare to httpserver. use rec service with DVBViewer for unicast Quote Link to comment
ml 05019 Posted October 31, 2011 Share Posted October 31, 2011 I thought I won't start a new topic because this bug is also pretty old one - but needs to be fixed someday. Right click -> View -> Zoom -> Zoom 100% resizes DVBViewer window to right height, but width is "taken from the ceiling" as Russians say. In other words, window is resized to some fixed width which is wrong and needs to be resized manually. And there's no difference if the video is 4:3 or 16:9, width is the same Here'sin case you need it. Quote Link to comment
ml 05019 Posted October 31, 2011 Share Posted October 31, 2011 (edited) Here's a few screenshots demonstrating the issue, both taken immediately after selecting "Zoom 100%" - note the black fields above & below the video Edited October 31, 2011 by ml 05019 Quote Link to comment
bogdan1980 Posted November 1, 2011 Share Posted November 1, 2011 i do not have this bug on my setup. try another skin maybe. Quote Link to comment
ml 05019 Posted November 3, 2011 Share Posted November 3, 2011 Which skin do you mean? I tried changing OSD skin and icons skin with no luck, and I have a "No skin" setting for DVBViewer window. Quote Link to comment
