morlook Posted November 8, 2011 Posted November 8, 2011 Hi there, Can anyone tell me how to stream to android w/ subtitles?? I'm using bs player and RS 1.9.2. Thank you all guys!!! Morlook
mague Posted November 8, 2011 Posted November 8, 2011 (edited) Works only for non-transcoded videos. And not with DVB or teletext subtitles. You 'll need a UPnP client and a Videoplayer supporting subtitles. Check out UPnPlay on the market. As player i use VPlayer, but there are most probably others with subtitle support. Edited November 8, 2011 by mague
bogdan1980 Posted November 10, 2011 Posted November 10, 2011 this stupid vplayer does not install on all android telephones.
moviefuns Posted November 17, 2011 Posted November 17, 2011 Try Daroon Player. It works on my optimus 2X, including subtitles and soundtracks.
bogdan1980 Posted November 17, 2011 Posted November 17, 2011 i have daroon, but vplayer is the best on android. On android, with daroon, for any other upnp software or dlna, frame rate is awfull on live-tv. On iphone, it's just work:P
bogdan1980 Posted September 15, 2012 Posted September 15, 2012 (edited) Now in 2012, on an Galaxy S2 i use: bubbleupnp pro + mxplayer pro, or diceplayer( with libffmpeg.so on SD card for DTS sound), or vplayer https://play.google.com/store/apps/details?id=com.bubblesoft.android.bubbleupnp&hl=en imediashare + mxplayer pro, or diceplayer, or vplayer http://www.imediashare.tv/ I love this imediashare, its awsome. All of these has dvb subtitles on all channels. If i use iphone webpage with Flowplayer, subtitles do not appear. If i use bubbleupnp or imediashare, i could watch HD channels, but framerate are low, Galaxy S2 hasnt enough power. But in my country RO all HD channels has SD equivalent. HD channels work ok with Flowplayer. Edited September 15, 2012 by bogdan1980
