toughcanny Posted November 17, 2011 Posted November 17, 2011 (edited) Hi, I bought dany u-2000 usb tv module to watch tv / satellite and then installed progdvb. I am not able to view any channel. When I went to Hardware under Options setting, I see nothing list in Device box. I dont know my device is being recognized or not. I am sure I have properly installed its driver and I can view USB TV device in my computer device manager. Please let me know how can i configure this thanks Edited November 17, 2011 by toughcanny Quote
Griga Posted November 17, 2011 Posted November 17, 2011 and then installed progdvb This is the DVBViewer forum. Ask your question in the progdvb forum. Or purchase DVBViewer Quote
toughcanny Posted November 17, 2011 Author Posted November 17, 2011 This is the DVBViewer forum. Ask your question in the progdvb forum. Or purchase DVBViewer Hmmmm, ok, here before purchasing, I also installed DVBViewer demo version, but here I can not see that. Kindly let me know how it works and how I can see satelite channels? Thanks Quote
hackbart Posted November 17, 2011 Posted November 17, 2011 1. Did you installed the driver for your adapter? 2. Is the adapter listed under options->hardware inside the DVBViewer demo? If so, make sure that you have installed some decoders in order to decode the audio and video signal. Usually at least if you have windows 7 installed you already have them from Microsoft, otherwise install proper decoders (i'm pretty sure that you find some of them on your driver cd). Christian PS: Are you sure that the stick is a DVB adapter? Quote
Griga Posted November 17, 2011 Posted November 17, 2011 I've downloaded the driver and had a look at it. Seems to be a stick for analog TV, not for digital TV (DVB). Analog TV is not supported by DVBViewer, and I guess the same applies to progdvb. Quote
toughcanny Posted November 17, 2011 Author Posted November 17, 2011 1. Did you installed the driver for your adapter? 2. Is the adapter listed under options->hardware inside the DVBViewer demo? If so, make sure that you have installed some decoders in order to decode the audio and video signal. Usually at least if you have windows 7 installed you already have them from Microsoft, otherwise install proper decoders (i'm pretty sure that you find some of them on your driver cd). Christian PS: Are you sure that the stick is a DVB adapter? Yes, I have installed the driver but it is not listed under hardware section I there any way to view satellite channel or it is useless for me? Quote
toughcanny Posted November 17, 2011 Author Posted November 17, 2011 I've downloaded the driver and had a look at it. Seems to be a stick for analog TV, not for digital TV (DVB). Analog TV is not supported by DVBViewer, and I guess the same applies to progdvb. Thanks all for replying. Oh! I havnt much idea and difference between analog and digital once. Is this useless for me? How can I view the satellite channels and using which software? If any way to use this one does it has limited feature or number of channel as compare to digital one? Quote
Griga Posted November 17, 2011 Posted November 17, 2011 and using which software? Install and use the software that is bundled with this stick. Or download it from danytech.com. http://www.danytech.com/presentation/viewcontent.aspx?Content_Id=5 Quote
toughcanny Posted November 17, 2011 Author Posted November 17, 2011 Install and use the software that is bundled with this stick. Or download it from danytech.com. http://www.danytech.com/presentation/viewcontent.aspx?Content_Id=5 I am already using the software provided in cd but can't view any thing and in device manager of my computer, under sound video and game controller i can see USB TV Device is there Quote
Griga Posted November 17, 2011 Posted November 17, 2011 Well, analog satellite TV is dying out. Which satellite position do you receive? Maybe there are no analog broadcasts anymore. Quote
toughcanny Posted November 17, 2011 Author Posted November 17, 2011 Well, analog satellite TV is dying out. Which satellite position do you receive? Maybe there are no analog broadcasts anymore. I guess it is Nilesat 101/102 like this. Oh it means my this device is going useless Quote
Griga Posted November 17, 2011 Posted November 17, 2011 Oh it means my this device is going useless It is. You can see it here: http://www.lyngsat.com/nile101.html http://www.lyngsat.com/nile102.html Everything DVB-S and DVB-S2 (Digital Video Broadcasting, DVB-S2 is an advanced DVB-S version). You need a DVB-S/S2 USB box or a DVB-S/S2 PCI card for satellite reception. It will work with DVBViewer. Quote
