robbie2 Posted November 26, 2011 Posted November 26, 2011 (edited) Two suggestions for TransEdit: On my setup, ‘Help’ is greyed out despite files TransEdit.chm and TransEditHelp.ini being in the same directory as TransEdit.exe. If another step is required in order to fix this, could some guidance on this be provided in the TransEdit notes. Also, could TransEdit Help include a reminder that pressing F1 will provide info on the current item. Thanks Cheers Edited November 26, 2011 by robbie2 Quote
Griga Posted November 26, 2011 Posted November 26, 2011 On my setup, ‘Help’ is greyed out despite files TransEdit.chm and TransEditHelp.ini being in the same directory as TransEdit.exe. It's a bug. Will be fixed. Thanks for the report. Also, could TransEdit Help include a reminder that pressing F1 will provide info on the current item. How? Quote
robbie2 Posted November 26, 2011 Author Posted November 26, 2011 It's a bug. Will be fixed. Thanks for the report. How? Thanks for the reply. Forget the second item - I originally thought F1 it was going to individual items, but I now see that F1 simply loads the manual. Sorry. One other minor point, I notice that TransEdit treats frequency 11126.5 (on Astra 1N) as 11126, whereas I would have expected it to be rounded up to 11127 (as it is usually quoted). I don’t know whether rounding is something that you would want to review for future versions of TransEdit. Cheers Quote
Griga Posted November 26, 2011 Posted November 26, 2011 I notice that TransEdit treats frequency 11126.5 (on Astra 1N) as 11126 The Delphi runtime library is doing it this way (the StringToFloat and Round function), dunno why... I would rather support floating point satellite frequencies, because SCPC (Single Channel Per Carrier) transponders often require more exact tuning, and the BDA interface expects the frequency as kHz, so 11126 MHz must be converted to 11126000 kHz anyway. However, it would cause some compatibility issues. Particularly the export formats (dictated by DVBViewer) are requiring MHz integer values... Quote
EnoSat Posted November 27, 2011 Posted November 27, 2011 (edited) Hi, planned added support for Multistream ? etc. ZeonBug (31East) , TivuItalia (31East) , Timb (12West) Edited November 27, 2011 by EnoSat Quote
Antonio Posted March 6, 2012 Posted March 6, 2012 (edited) Hi!!! How to make sorting in heading "Description" on decrease/increase to number. It seems doesn't work for example In other headings the sorting it works Edited March 6, 2012 by Antonio Quote
Griga Posted March 6, 2012 Posted March 6, 2012 The description column is sorted alphabetically, not numerically, because it is supposed to contain text information. If you want it to be sorted by db values, you must enter them in the following way: 09.4 db 07.7 db ... 13.9 db ... etc. Make sure that each value has two digits before the decimal point. Quote
Antonio Posted March 6, 2012 Posted March 6, 2012 OK. My *.ini files is generated after BLScan utility search. (BLScan.exe V.1.1.0.912) It is a lot of correcting work now. But all the same thanks for the answer. Quote
