Crunchy Posted December 22, 2011 Posted December 22, 2011 I hope someone can help! I can play BBC radio 5L, BFBS and a few other radio channels but have lost sound/reception on BBC Radio 1, 2, etc. I used to be able to listen to these channels but they suddenly went. All the TV channels work properly. What could be the problem??? Quote
Ducatirider Posted December 24, 2011 Posted December 24, 2011 ..wrong entries in your channel list How do you rectify the problem? Quote
Crunchy Posted December 27, 2011 Author Posted December 27, 2011 I've updated the channel lists but still no sound. I get the info about what is being broadcast though. All the other channels from BskB and radio 5 work no problem, just everything from BBC London too BBC R4 don't. Is there anything I can do or is this an issue with the BBC? Quote
QBox User Posted December 28, 2011 Posted December 28, 2011 Seems OK for me. That transponder (11954H) was changed a few months ago to accommodate the "red button" streams, but I don't know if any radio settings were changed. Try re-scanning and updating the channels. Quote
Tjod Posted December 28, 2011 Posted December 28, 2011 May be thy are using AC3 and there is a problem with your AC3 decoder. Quote
Griga Posted December 28, 2011 Posted December 28, 2011 May be thy are using AC3 No. Crunchy should provide more information, e.g. a support.zip and/or a channel editor screenshot showing his radio channel settings. Otherwise it's just blind guessing. Quote
QBox User Posted December 28, 2011 Posted December 28, 2011 Assuming (from BFBS) we are actually talking about satellite and not terrestrial, the parameters for BBC R1 are: 11953, H, 27500, 2/3, Stream ID 2013, QPSK, Service ID 6751, Audio PID 5401, Audio type MPEG, PMT 259, Language eng, PCR 5401 Check these in channel editor Quote
Ducatirider Posted January 1, 2012 Posted January 1, 2012 OK, I've since my last post, updated my computer and have therefore had to reinstall DVBViewer. The problem I have now is that BBC Radio 1, 2 etc don't even show up after the scan. Can anyone send me a transponder list with them on. Thanks! Btw, I falsely logged on as Crunchy which was my old user name when I first posted this problem; sorry for the confusion Quote
QBox User Posted January 3, 2012 Posted January 3, 2012 (edited) You can add the transponder in TransEdit using the parameters above, or else download a list from this forum. http://www.DVBViewer.tv/forum/topic/40800-transponder-lists-for-DVBViewer/ Edited January 3, 2012 by QBox User Quote
Ducatirider Posted January 3, 2012 Posted January 3, 2012 Thanks QBox user, I put the frequencies in but still got nothing. I am now thinking that the problem lies with the dish; that it has maybe shifted slightly. Having said that, I tried to update the channel list from the link you posted yet can't seem to load them into the channel list editor. When I click import, nothing happens?????? Quote
QBox User Posted January 3, 2012 Posted January 3, 2012 The link was to an updated list of transponders, not channels. Download the exe file for DVBViewer format and execute. It should update your transponder lists with the latest details. Use TransEdit to scan 11953H on 28.2E. Quote
Ducatirider Posted December 13, 2012 Posted December 13, 2012 Hi guy's, I'm back with the same old problem: most bbc radio channels not playing. The difference this time is that I have fitted a new DBS2 TV card and have still the same problem. As previously stated, I thought it was the satellite dish it's self but I have had that checked out (I get radio 2 on my sky box) I have updated and checked the freqencies, but still know stations. I do have though, Radio 5 live. Is there something that I missing here????? Thanks inadvance for any tips Paul Quote
Ducatirider Posted December 13, 2012 Posted December 13, 2012 I'ts me again. Problem sorted. I scrolled down the channels list (audio) and took a look in BskyB, just on the off chance clicked on Radio 2and the rest is history. Thanks for your support in the past guys. Quote
