ginacman Posted January 2, 2012 Posted January 2, 2012 Hello, I just upgraded DVBViewer to the 4.9 version and I much appreciated the H.264 filler data removal option while recording new contents. In fact, I got in the past many problems at playing the .TS H.264 captures on my mediaplayer (it's a DUNE) because the audio format was not correctly recognized in many cases - a fake DTS format was shown and tried, in place of the correct AC3) - but now, through the filler removal option, I'm able to play the audio track of the new recordings. Nonetheless, still the same problem remains with my archive of previous captures. Is it possible to remove the filler in already recorded material, perhaps using a plugin or a similar external tool? Thank you. Quote
Griga Posted January 2, 2012 Posted January 2, 2012 Is it possible to remove the filler in already recorded material, perhaps using a plugin or a similar external tool? Yes. With TSPlayer (download from the members area / tools section). Tick the according checkbox on the conversion tab, then start a TS -> TS conversion. The manual tells you how to do it. Quote
ginacman Posted January 4, 2012 Author Posted January 4, 2012 It worked very well and solved my problem, the audio track is now correctly played, thanks! Marco Quote
HaraldL Posted January 4, 2012 Posted January 4, 2012 And it saves HDD space without any loss of quality Quote
dvbrewer Posted January 5, 2012 Posted January 5, 2012 And it saves HDD space without any loss of quality So what is the point of the filler data ? Quote
HaraldL Posted January 5, 2012 Posted January 5, 2012 So what is the point of the filler data ? Some broadcasting companies insert them to get a constant data rate on the transponder as I read. So scenes with low bitrate get more filler data. Quote
dvbrewer Posted January 7, 2012 Posted January 7, 2012 Some broadcasting companies insert them to get a constant data rate on the transponder as I read. So scenes with low bitrate get more filler data. That's confusing, are you saying that applies to channels that use a fixed bitrate or a variable bitrate? Quote
Griga Posted January 7, 2012 Posted January 7, 2012 Channels with variable bitrate are stuffed in order to achieve a constant bitrate, thus fulfilling technical (muxing) requirements, particularly if dynamically balanced muxing is not possible. Quote
