Timeline Font Size no save?
majstang
Many new exciting features indeed :) It takes a while to catch up with all of them, I believe.
I have pretty much the same issue as @Knilch posted in the German section:
http://www.DVBViewer.tv/forum/topic/48026-version-193/page__view__findpost__p__353421
The selected font size in timeline do not get saved, if one exits the browser (Chrome with cookies enabled) and restart, the default font size gets loaded. Its a bit hard to follow that particular thread since the translation doesnt make much sense (viva google) ;)
Using the default settings in Chrome. Any pointers how to solve this?
I've looked into the code from @mrphlox (he did all the work on the timeline and inspired me to change the tvguide). It seems the cookies he sets are only for the current session. To solve this you would have to change the minified js file. which is a little difficult... :(
I see, well it is no biggie! I will gladly wait for a solution down the road :)
yes indeed, I'll change that in the next version. This and other settings of the timeline will be persisted and will therefore survive a restart of the browser.
