SerTak Posted January 10, 2012 Posted January 10, 2012 (edited) Hi all, I'm new of the forum and... Italian, so my English can be orrible, sorry! I'm trying before buy the progam but I have 2 problem: 1. The automatic channel search don't find some channels, for example "Discovery Science" or "AXN Italia" in sky Italy package. This channels are regularly found by other sw (progdvb for example). How can I force the search with the values in this page? The values in this page are useful? 2. I need to try the HD Nvidia Plugin ((From this forum page)) but i'm not able to enter the member area. I'm sure that my Vobo is nvidia with PureVideoHD (I use MediaPlayerClassic for use this feature playing HD videos and is perfect). For my Hardware limitation when I play a HD channel the image snaps (jump? Isn't fluid? How do you tell in English "scatta"?). How can I try this plugin in demo version? How can i download it? My HW: CPU AM2 3200+, Vobo nVidia 8400gs, 4Gb Ram, Win7 64Bit, SkyStar HD 2 (sat). Thank to everybody that will answer! Bye Edited January 10, 2012 by SerTak Quote
Tjod Posted January 10, 2012 Posted January 10, 2012 i'm not able to enter the member area. And where does you got the DVBViewer Pro from? https://www.DVBViewer.tv/members/ Quote
SerTak Posted January 10, 2012 Author Posted January 10, 2012 i'm still using the demo version: http://www.DVBViewer.com/en/index.php?page=downloads if i'm not sure that the plugin is perfectly running with my system i'll not buy the software and probably will pass to another one Quote
QBox User Posted January 10, 2012 Posted January 10, 2012 1. The transponder list supplied with the demo version is not up to date. Edit the file 0130.ini in the Transponder folder and change this: 31=11355,V,27500,34,1,|SkyItalia to this: 31=11355,V,29900,34,1,|SkyItalia as per your link. The Skyitalia transponder for Disc. Science etc. should then scan. You may need to make the same change to symbol rate for other Skyitalia transponders 11219H, 11900H, 12072V, 12616H Quote
QBox User Posted January 10, 2012 Posted January 10, 2012 2. Why do you need the plug-in? If you just want to try the NVidia PureVideo decoder, then different DirectShow codecs can be selected in DVBViewer - Settings - Options - DirectX. Microsoft Win7 ones are usually pretty good for video, even H264 (though you may need a better audio one for AC3). Choose EVR custom renderer. Quote
SerTak Posted January 10, 2012 Author Posted January 10, 2012 (edited) Ok i've buyed the full version. Now I know that this is a super SW! I find all channels and fullHD is perfect! Another question... how to play MKV files? QBox: really thank you for your help!!! Edited January 10, 2012 by SerTak Quote
QBox User Posted January 10, 2012 Posted January 10, 2012 Think you need a splitter for mkv. Enter the question into Search box at top of page and you will get an answer quickly. Quote
