Using other codecs for WMV?
dvbrewer
Trying setting the Video B codec to MPC or ffdshow and adding .wmv in the auto B conditions does not seem to do anything, please allow these other codecs to be used as they are much more efficient than WMVideo Decoder DMO.
There is no codec setting for WMV. So the DirectShow system is used. Which result in using the codec with the highest Merit value.
You can change the Merit value with RadLight Filter Manager.
http://www.DVBViewer.com/griga/rlfm_bin1_6.zip
Or you can build a GraphPresets
http://www.DVBViewer.tv/forum/topic/46961-DVBViewer-pro-49/
http://www.DVBViewer.tv/forum/topic/46975-graph-presets-einfacher-editor/
http://de.DVBViewer.tv/wiki/GraphPresets
It is pain to mess with the WMVideo Decoder as it part of Windows, so I I'll try the graphpresets, I'll let you know how I get on, thanks. CPU usage is much less with Windows Media Player/Center or VLC than with the MPC-HC decoder, not sure why that is.
OK I finally worked out how to do it, the result is much, much better, less than half the CPU usage with WMVideo Decoder in DVBViewer using CUVID (with NVidia, next LAV release has DXVA acceleration), pretty much the same as in WMP or VLC usage. Below is the preset file to use (after you install LAV Video & Audio decoder) :bye::
Copy this into notepad and save as WMV.fgp, place in [configuration folder]\GraphPresets\ folder
[General]
DisplayName=WMV
Description=WMASF/LAV
Conditions=.wmv
Enabled=1
[sourceFilter]
CLSID={187463A0-5BB7-11D3-ACBE-0080C75E246E}
Name=WM ASF Reader
[splitter]
CLSID=
Name=
[VideoDecoder]
CLSID={EE30215D-164F-4A92-A4EB-9D4C13390F9F}
Name=LAV Video Decoder
[AudioDecoder]
CLSID={E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
Name=LAV Audio Decoder
[VideoRenderer]
Name=EVR Custom Video Renderer
Custom=1
[AudioRenderer]
Name=ReClock Audio Renderer
Edited by dvbrewer
In case people wonder why this is the case, it is because the Microsoft WMVideo Decoder does not allow any acceleration outside of Windows Media Player/Center. The next version of LAV will allow DXVA acceleration for AMD/ATi, possible Intel also.
  • 3 weeks later...
It appears LAV is not actually using CUVID to decode WMV9, it is just a very efficient CPU decoder.
