Usals
wikings1
Hello i wonder if it possible to have a function that scans all you active sattelites
Right now you need to scan everysattelite manually.
Little lazy hehe
Regards wikings1
  • 4 weeks later...
Little lazy hehe
Regards wikings1
and to add, to place the angular position automatically and manually in each satelite
Both would be an excellent idea and I was about to request the same and would like to add one option:
1) Change the setting for all or selected satellites at once to Angular Position
2) Scan or update, all or selected satellites.
3) Scan with possibility to 'delay scan' (when a motor is being used), to give a certain delay to give the motor time to position.
This last one could be
- Entered into a fixed amount of seconds (as not all motors move at same speed, even speed differs when H/V is used because of a change in voltage)
- Or x degrees/second. As long as DVBViewer 'knows' what current position is, it could be using a delay that will be like 1 second/degrees. So from 19.2 to 13.0 east, would give a scan-delay of 6 seconds.
