FYI: Success with new driver for Technisat Skystar 2
arnomd
FYI: a success story that might be helpful to owners of Technisat Skystar 2:
I have been using the Technisat Skystar 2 for a number of years with the Technisat TE2 program.
Recently I updated to the DVBViewer pro program.
There was not driver with the pro version and installing the drivers manually did not work, son I had to install the old Technisat TE2 program as well.
(the program: 'soft_4.6')
For some hardware into see: http://de.DVBViewer.tv/wiki/Unterst%C3%BCtzte_Hardware
But I still ran into difficulties:
The pro program would only record manually - but not with with EPG or with manual timesetting.
The ('accidental') solution was the new Technisat TE2 program: 'soft_deen_SkyStar12-TV_001'
See: http://www.technisat.com/de_DE/Service-&-Downloads/352-8/
Installing it solved the problem.
Removing it later made no difference, the pro program still worked.
