need advice updating from 4.2 to current version
stax
Most of the time I'm only using the timer for recording and I'm afraid updating takes much time or cause problems though a cannot remember much problems in the past.
A issue with 4.2 is lack of native High DPI support, by default which I'm using DPI Virtualization is used causing the complete user interface being blurry.
Another problem I have is minimizing the timer or EPG window hides it without a chance to show it again.
Were these issues fixed meanwhile?
Edited by stax
I can only recommend that you upgrade to the latest version. As ususal make a backup of your old installation, but DVBViewer has definitely lots of new stuff since 4.2.
I've updated now without much problems so far, I was disappointed however High DPI is still not supported.
