Tyro Posted February 13, 2012 Posted February 13, 2012 I´m trying to get the recording service to work but I can´t find out how I can get EPG-data from tvguide.xml (the file where Xepg store the epg-data) into recording service. Quote
Tjod Posted February 14, 2012 Posted February 14, 2012 You have to import it via Xepg. http://www.a123.dk/ Quote
majstang Posted February 14, 2012 Posted February 14, 2012 I´m trying to get the recording service to work but I can´t find out how I can get EPG-data from tvguide.xml (the file where Xepg store the epg-data) into recording service. You create a RS task-rightclick RS systray icon-Configure-Tasks and fill in: Filename: C:\Program\Xepg\Xepg.exe Parameters: -xGrabThenImport WorkDir: Empty When executing the task from RS (either as a timer or manually) Xepg fires up your grabber and then imports the tvguide.xml into RS epg.dat. Then check RS timeline to see the new EPG. Quote
