Editing & Cutting with PVAcut
Henk
Since more and more of us seem to be growing fond of PVAcut as an editing tool for the PVA files I wanted to repeat the following questions:
The PVAcut displays 5 squares to click on when choosing the beginning and end of a selection. However the position can only be chosen by using the slider & the result viewed in the PVAview window. which is pretty inexact or a bit difficult to work with.
(When clicking before or after the slider you always get the next 5 mpeg2 packets.) Only when clicking directly on the slider it moves backwards by only 1 packet.
Is there a way to display in the PVAview window the contents of the packet you click on ?
Or does someone know if the packet displayed in the PVAview, is it the 1st, last, or middle of the 5 packets listed in the five squares?
I guess that would already be a help since you can at least move backwards by one packet.
Or can someone recommend another good (preferably free) tool for editing & cutting PVAs?
Thanks for your help!
i think you have to mark the Block(Frame ###### over the slider,than PVA-Cut use the I-Frame to cut,this is exactly defined.
You can change the Point ,look the options.
Point and Framenumber you see also.
Greets Plubsi
Short Answer from Michael Tirtasana re: PVAcut Questions:
(I had sent him an e-mail, here it is (answers by M.T.):
> Is there a way to display the contents of the packet you click on in
> the PVAview window?
NO
> ... the packet displayed in the PVAview, is it the
> 1st, last or middle of the 5 packets listed in the five squares?
The Bar and Arows shows the Frame which is display. It is the 3Third
Paket
> backwards by one.
Michael
Dipl.- Inf.[FH]
Michael Tirtasana
E-mail: tirtasana@gmx.de
Homepage: http://www.tirtanium.de
