Recording Service 1.93 hangs stopping
therac
I am trying to use V 1.93 of the Recording Service to stream to a variety of devices. On a number of occasions, I have used remote desktop either from Android or PC to control the PC running the service, and tried to restart the service after a hang (well actually a lack of response over the network). On logging into the PC, I find that the DVBViewer Recording Service is visible in the Services view, and its state is stuck (forever) at 'Stopping'. I have to reboot the PC to get any response - other applications seem unaffected. It's a shame, because this is a very convenient way to view the PC on my Android tablet, and the quality is excellent (although Flowplayer will insist on firing up in a small window, with no 'Full Screen' control - avoidable by opening in another tab in Opera Mobile, when it goes to full screen.
On a separate issue - any guidance on which ports to open in a firewalled router to access the recording service via the web interface would be really helpful!
PC is a core i7 Intel, with a Geforce 560TI and the latest nvidia drivers. I am suspicious of the cheap USB tuner I am using - however it works very reliably with BDA drivers under DVBViewer.
But a great piece of code - not quite so complementary about the English documentation...
Edited by therac
Hi, the Webserverport (to be opened and forwarded to the pc running the service) is 8089 by default but configurable via the respective Item accessible by rightclicking the service tray icon - should also be visible in the adressline of your browser when accessing the page.
Regarding your reboots - a less brutal and much faster way should be to kill the process in the taskmanager and then restart it via tray icon menu - though of course thats no satisfying situation but probably caused by communication problems between the service and the upnp client.
Sorry - I thought I had uploaded the support file.
It appears that the support.zip file is 833kbytes, and my global upload quota is 505k bytes...
Just checked - it appears that one of the files in the zip, svcdebug.log is over 20Mbytes
I have deleted that file and attach the remaining content
Anyone who is capable of getting themselves made President should on no account be allowed to do the job.
Douglas Adams
Edited by therac
FWIW, tail of the svcdebug.log is as follows - there are a LOT of ffmpeg errors...
15.02.12 21:41:51.389 FFMPEG [mpeg2video @ 0000000001D4F900] concealing 44 DC, 44 AC, 44 MV errors
15.02.12 21:41:51.389 FFMPEG frame= 8697 fps= 25 q=20.0 size= 0kB time=00:05:46.44 bitrate= 0.0kbits/s
15.02.12 21:41:51.976 FFMPEG frame= 8710 fps= 25 q=20.0 size= 0kB time=00:05:46.96 bitrate= 0.0kbits/s
15.02.12 21:41:52.505 FFMPEG frame= 8723 fps= 25 q=21.0 size= 0kB time=00:05:47.48 bitrate= 0.0kbits/s
15.02.12 21:41:53.030 FFMPEG frame= 8737 fps= 25 q=18.0 size= 0kB time=00:05:48.04 bitrate= 0.0kbits/s
15.02.12 21:41:53.527 FFMPEG frame= 8749 fps= 25 q=19.0 size= 0kB time=00:05:48.52 bitrate= 0.0kbits/s
15.02.12 21:41:54.053 FFMPEG frame= 8764 fps= 25 q=18.0 size= 0kB time=00:05:49.12 bitrate= 0.0kbits/s
15.02.12 21:41:54.609 FFMPEG frame= 8777 fps= 25 q=18.0 size= 0kB time=00:05:49.64 bitrate= 0.0kbits/s
15.02.12 21:41:55.138 FFMPEG frame= 8792 fps= 25 q=19.0 size= 0kB time=00:05:50.24 bitrate= 0.0kbits/s
15.02.12 21:41:55.612 FFMPEG frame= 8800 fps= 25 q=19.0 size= 0kB time=00:05:50.56 bitrate= 0.0kbits/s
15.02.12 21:41:56.159 FFMPEG frame= 8813 fps= 25 q=20.0 size= 0kB time=00:05:51.08 bitrate= 0.0kbits/s
15.02.12 21:41:56.655 FFMPEG frame= 8824 fps= 25 q=20.0 size= 0kB time=00:05:51.52 bitrate= 0.0kbits/s
15.02.12 21:41:57.161 FFMPEG frame= 8838 fps= 25 q=20.0 size= 0kB time=00:05:52.08 bitrate= 0.0kbits/s
15.02.12 21:41:57.713 FFMPEG frame= 8853 fps= 25 q=21.0 size= 0kB time=00:05:52.68 bitrate= 0.0kbits/s
15.02.12 21:41:58.211 FFMPEG frame= 8867 fps= 25 q=21.0 size= 0kB time=00:05:53.24 bitrate= 0.0kbits/s
15.02.12 21:41:58.798 FFMPEG frame= 8881 fps= 25 q=22.0 size= 0kB time=00:05:53.80 bitrate= 0.0kbits/s
15.02.12 21:41:59.290 FFMPEG frame= 8896 fps= 25 q=24.0 size= 0kB time=00:05:54.40 bitrate= 0.0kbits/s
15.02.12 21:41:59.794 FFMPEG frame= 8908 fps= 25 q=23.0 size= 0kB time=00:05:54.88 bitrate= 0.0kbits/s
15.02.12 21:42:00.347 FFMPEG frame= 8922 fps= 25 q=22.0 size= 0kB time=00:05:55.44 bitrate= 0.0kbits/s
15.02.12 21:42:00.818 FFMPEG frame= 8933 fps= 25 q=23.0 size= 0kB time=00:05:55.88 bitrate= 0.0kbits/s
15.02.12 21:42:01.337 FFMPEG frame= 8944 fps= 25 q=21.0 size= 0kB time=00:05:56.32 bitrate= 0.0kbits/s
15.02.12 21:42:01.403 tStreamClient Release USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:01.403 tStreamClient Destroy USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:01.956 tStreamClient Destroyed USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:01.956 tStreamClient hamDeleted USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:01.956 ReleaseStandbyblock TStreamClient
15.02.12 21:42:01.956 SetThreadExecutionState 0x80000000
15.02.12 21:42:01.956 Releasereference TStreamClient: 0
15.02.12 21:42:04.234 TBDATechnoTrend.Opendevice TT Device: 3
15.02.12 21:42:04.367 TBDATechnoTrend.Opendevice bvTechnoTrend
15.02.12 21:42:04.367 TEPGUpdater Allocate USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:05.021 ParseSI Bad CRC
15.02.12 21:42:35.021 TEPGUpdater Allocate USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:35.021 TEPGUpdater Release USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:46.203 client doflashstream Preset=3&aspect=16%3A9&ffPreset=normal&maxwidth=&maxheight=&chid=5
15.02.12 21:42:46.203 Converter Start cmd -threads 8 -er 4 -i "http://192.168.1.42:7522/upnp/channelstream/oneaudio/5.ts" -threads 8 -f flv -vcodec libx264 -bufsize 1024k -b:v 1200k -bt 1300k -r 25.0 -map 0:0 -map 0:1 -vf "yadif=0:-1:1, scale=min(800\, trunc(iw/2)*2):trunc((ow/dar)/2)*2" -vpre normal -vprofile baseline -level 30 -acodec libmp3lame -ab 192k -ar 44100 -ac 2 -async 1 -y "\\.\pipe\Output{3860D570-425D-4C21-A52E-3BC10E99B76A}"
15.02.12 21:42:46.225 SetStandbyblock TStreamClient
15.02.12 21:42:46.225 SetThreadExecutionState 0x80000041
15.02.12 21:42:46.225 AddReference TStreamClient: 1
15.02.12 21:42:46.225 TEPGUpdater Release USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:46.225 TEPGUpdater Destroy USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:46.778 TEPGUpdater Destroyed USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:46.778 TEPGUpdater hamDeleted USB 2.0 BDA DVB-T Tuner
15.02.12 21:42:47.043 TBDATechnoTrend.Opendevice TT Device: 3
15.02.12 21:42:47.160 TBDATechnoTrend.Opendevice bvTechnoTrend
15.02.12 21:42:47.160 tStreamClient Allocate USB 2.0 BDA DVB-T Tuner
