madsilence Posted February 21, 2012 Posted February 21, 2012 (edited) Hi. I have a TT S2-1600 card and I'm a legal DVBViewer user (just to say that I'm up to date version 4.9). Tried S2-1600 drivers versions from 5.0.18 to 5.0.35 originals and their modified versions with up to 900ma static current permitted - no result. Problems with protocol 1.2 are: - "Positioner console" is inactive in TransEdit (two last newer versions), so no way to enter into positioner menu.(why are you checking the 1.2 support at all?? why it is not possible just sent a diseqc command I want?)No way to get here http://www.DVBViewer.com/griga/TransEdit%20E/DiSEqC.html#Positioner - Switching to motor presets doesn't move motor directly from the DVBViewer. So, there is no way to work with motor. Protocol 1.1 doesn't work as well. 4 LNBs with 1.0 work fine. MyTheatre works fine with both 1.1 and 1.2 protocols with the same drivers, why DVBViever does not? Best regards. Edited February 21, 2012 by madsilence Quote
Griga Posted February 22, 2012 Posted February 22, 2012 Probably you have overlooked the checkbox for additional TechnoTrend support in the DVBViewer Pro installer. Without the file ttBdaDrvApi_Dll.dll (also available here) DiSEqC 1.2, CI, remote control support etc. are not available. why are you checking the 1.2 support at all?? Because it allows to diagnose such installation faults even if users ignore the "How to post problems/bugs correctly" hint at the top of this page. Quote
madsilence Posted February 22, 2012 Author Posted February 22, 2012 (edited) Thanks a lot, Griga. Now S2-1600 works fine with 1.2. I put this dll into root folder of DVBViewer. The same questions for Hauppauge HVR-4000 card (my father's hardware). Should it work with "default" DVBViewer installation? (it doesn't work now with default). I'm asking about default because "Positioner console" is active in TransEdit with HVR-4000 but seems 1.2 does not work.... Is it necessary to put any dll into root folder of DVBViewer for HVR-4000? Edited February 22, 2012 by madsilence Quote
Griga Posted February 22, 2012 Posted February 22, 2012 Is it necessary to put any dll into root folder of DVBViewer for HVR-4000? No. The driver provides DiSEqC 1.2 support without additional files. Maybe this helps: http://www.DVBViewer.tv/forum/topic/28267-no-4-way-diseqc-with-vista/page__view__findpost__p__223347 Quote
madsilence Posted February 23, 2012 Author Posted February 23, 2012 Thanks a lot Griga. Now works with both cards Quote
