Nigel P Posted February 28, 2012 Posted February 28, 2012 Hi Is there an API/WebService that will allow me to extract what the Recording Service is currently recording? (The info on the Status webpage would be ideal) so I can display this on a 4x20 char LCD display. Thanks Nigel
majstang Posted February 28, 2012 Posted February 28, 2012 No, not through the RS API. http://en.DVBViewer.tv/wiki/Recording_Service_API Should be possible with a script though.
Lars_MQ Posted February 28, 2012 Posted February 28, 2012 You could use the api/timerlist.html. you have to sort the entries by date/Starttime yourself and look for <Recording> Tag <> 0. this would give you all needed information about running recordings (could be far more than one) and you could calculate the next upcoming recording(s). The entires should be selfexplaining.
Nigel P Posted February 28, 2012 Author Posted February 28, 2012 You could use the api/timerlist.html. you have to sort the entries by date/Starttime yourself and look for <Recording> Tag <> 0. this would give you all needed information about running recordings (could be far more than one) and you could calculate the next upcoming recording(s). The entires should be selfexplaining. Thank you - That looks very useful. One more question though, I wanted to find out which Tuner is being used. Is that possible?
majstang Posted March 3, 2012 Posted March 3, 2012 Thank you - That looks very useful. One more question though, I wanted to find out which Tuner is being used. Is that possible? Yeah, it's possible! My approach to this thing you wanna do is to download the whole statuspage into a variable and start picking out the strings you're after. For example starting with this Autohotkey function and go from there: UrlDownloadToVar("http://127.0.0.1:8089/status.html?aktion=status", OutputVar) msgbox % OutputVar UrlDownloadToVar(URL, ByRef Result, UserAgent = "", Proxy = "", ProxyBypass = "") { ; Requires Windows Vista, Windows XP, Windows 2000 Professional, Windows NT Workstation 4.0, ; Windows Me, Windows 98, or Windows 95. ; Requires Internet Explorer 3.0 or later. pFix:=a_isunicode ? "W" : "A" hModule := DllCall("LoadLibrary", "Str", "wininet.dll") AccessType := Proxy != "" ? 3 : 1 ;INTERNET_OPEN_TYPE_PRECONFIG 0 // use registry configuration ;INTERNET_OPEN_TYPE_DIRECT 1 // direct to net ;INTERNET_OPEN_TYPE_PROXY 3 // via named proxy ;INTERNET_OPEN_TYPE_PRECONFIG_WITH_NO_AUTOPROXY 4 // prevent using java/script/INS io := DllCall("wininet\InternetOpen" . pFix , "Str", UserAgent ;lpszAgent , "UInt", AccessType , "Str", Proxy , "Str", ProxyBypass , "UInt", 0) ;dwFlags iou := DllCall("wininet\InternetOpenUrl" . pFix , "UInt", io , "Str", url , "Str", "" ;lpszHeaders , "UInt", 0 ;dwHeadersLength , "UInt", 0x80000000 ;dwFlags: INTERNET_FLAG_RELOAD = 0x80000000 // retrieve the original item , "UInt", 0) ;dwContext If (ErrorLevel != 0 or iou = 0) { DllCall("FreeLibrary", "UInt", hModule) return 0 } VarSetCapacity(buffer, 10240, 0) VarSetCapacity(BytesRead, 4, 0) Loop { ;http://msdn.microsoft.com/library/en-us/wininet/wininet/internetreadfile.asp irf := DllCall("wininet\InternetReadFile", "UInt", iou, "UInt", &buffer, "UInt", 10240, "UInt", &BytesRead) VarSetCapacity(buffer, -1) ;to update the variable's internally-stored length BytesRead_ = 0 ; reset Loop, 4 ; Build the integer by adding up its bytes. (From ExtractInteger-function) BytesRead_ += *(&BytesRead + A_Index-1) << 8*(A_Index-1) ;Bytes read in this very DllCall ; To ensure all data is retrieved, an application must continue to call the ; InternetReadFile function until the function returns TRUE and the lpdwNumberOfBytesRead parameter equals zero. If (irf = 1 and BytesRead_ = 0) break Else ; append the buffer's contents { a_isunicode ? buffer:=StrGet(&buffer, "CP0") Result .= SubStr(buffer, 1, BytesRead_ * (a_isunicode ? 2 : 1)) } /* optional: retrieve only a part of the file BytesReadTotal += BytesRead_ If (BytesReadTotal >= 30000) ; only read the first x bytes break ; (will be a multiple of the buffer size, if the file is not smaller; trim if neccessary) */ } DllCall("wininet\InternetCloseHandle", "UInt", iou) DllCall("wininet\InternetCloseHandle", "UInt", io) DllCall("FreeLibrary", "UInt", hModule) }
