xtonys Posted March 12, 2012 Share Posted March 12, 2012 Hi I have installed SVC 1.9.4.1 today. I have installed the latest version of ffmpeg also. It all works fine (apart from an issue with Skystar USB, which I posted elsewhere). Thumbs are created fine in C:\ProgramData\CMUV\DVBViewer\Images\Thumbs\Recordings For thumbnails, I want to dynamically reference these images for my duration.xml OSD. Can anyone please suggest what # reference I can use for this? I guess similar concept to #coverart? I also want to apply the following logic to the xml code that does this process... if music file use #coverart else use #svcart (or whatever this reference is called?) else use default image Im not a developer, so I know what i want to do, but dont know how to do it?! I have included the sections from duration.xml below. Coverart works fine when there is a music file being played. I know the reference to a specifc file is the wrong concept, but this is just related to my attempts to make the logic work. <item> <description>medialogo</description> <type>Image</type> <id>1</id> <x>220</x> <y>860</y> <width>160</width> <height>140</height> <texture>#coverart</texture> <keepaspectratio>true</keepaspectratio> </item> <item> <description>recordedtvimage</description> <type>Image</type> <x>220</x> <y>860</y> <width>160</width> <height>140</height> <texture>C:\ProgramData\CMUV\DVBViewer\Images\Thumbs\Recordings\folder.jpg</texture> <keepaspectratio>true</keepaspectratio> </item> It would be great to get this working. Thanks for any advice. Tony Link to comment
xtonys Posted March 12, 2012 Author Share Posted March 12, 2012 Related to thumbs, when recordings are deleted through OSD, is it possible for the related thumbs to be deleted also? Link to comment
