iriskin Posted March 14, 2012 Posted March 14, 2012 (edited) It started when i updated DVBViewer to 4.9.5. When i to switch channels within same transponder - next channel doesn't tune at all. I have to do "rebuild graph" - then it works. With 4.9.0 i did not have this problem. It happens only when i watch through RecService. Without it i don't have this problem. I tried changing all settings in Unicast Device in DVBViewer and in DVB Card hardware options in RecService. No success. DVB Card: Prof 7500 USB. Recording Service latest version 1.9.4.1 Beta I can attach screenshots. Take video of the process. Whatever. Just don't ignore this like other problem in previous topic: http://www.DVBViewer...alization-fail/ . Because i still have that problem sometimes on freshly installed Windows 7 Ultimate 64 bit( intialization failed and error TUCStreamThread Could not connect: Zugriffsverletzung bei Adresse 004AA29B in Modul 'DVBViewer.exe'. Schreiben von Adresse 0058B0C0 in osderror.log). Network without router. Cable goes straight to the NIC. Have no network problems in any other software. Edited March 14, 2012 by iriskin Quote
Kiwi_Tim Posted March 17, 2012 Posted March 17, 2012 I have the exact same problem as you after updating DVBViewer and Recording Service to the most current builds. I'm on a W7 Ultimate 32bit PC (AMD Athlon II X3 3.4 Ghz, 4GB DDR2-800). My satellite card is TeVii S480. I can confirm that this only occurs on DVB-S2 satellite channels. DVB-S and DVB-T channels function completely normally. The system was running completely normally before the DVBV & RS upgrade. Tim New Zealand Quote
iriskin Posted March 18, 2012 Author Posted March 18, 2012 I have the exact same problem as you after updating DVBViewer and Recording Service to the most current builds. I'm on a W7 Ultimate 32bit PC (AMD Athlon II X3 3.4 Ghz, 4GB DDR2-800). My satellite card is TeVii S480. I can confirm that this only occurs on DVB-S2 satellite channels. DVB-S and DVB-T channels function completely normally. The system was running completely normally before the DVBV & RS upgrade. Tim New Zealand thx for aswer. I saw people having similar problem on German forums. But devs still ignore it. No answer, no fix. For me it's the same for DVB-S2 and DVB-S. My guess is hardware database is screwed up so result is different for different DVB cards. Meanwhile lots of people still can't use RecService for several days and have no idea whether it's going to be fixed or not. Quote
Griga Posted March 18, 2012 Posted March 18, 2012 Be sure it's looked after. However, the reason for this issue is not quite clear yet. Quote
dobbeltseng Posted March 19, 2012 Posted March 19, 2012 It started when i updated DVBViewer to 4.9.5. When i to switch channels within same transponder - next channel doesn't tune at all. I have to do "rebuild graph" - then it works. With 4.9.0 i did not have this problem. It happens only when i watch through RecService. Without it i don't have this problem. I tried changing all settings in Unicast Device in DVBViewer and in DVB Card hardware options in RecService. No success. DVB Card: Prof 7500 USB. Recording Service latest version 1.9.4.1 Beta I can attach screenshots. Take video of the process. Whatever. Just don't ignore this like other problem in previous topic: http://www.DVBViewer...alization-fail/ . Because i still have that problem sometimes on freshly installed Windows 7 Ultimate 64 bit( intialization failed and error TUCStreamThread Could not connect: Zugriffsverletzung bei Adresse 004AA29B in Modul 'DVBViewer.exe'. Schreiben von Adresse 0058B0C0 in osderror.log). Network without router. Cable goes straight to the NIC. Have no network problems in any other software. I have the same problem. For me the problem occurs when changing between HD-channels only. I have tried on Win 7 32 and 64-bit, and on Windows 8 64-bit. I have both dbv-c and dvb-s(2) tuners from TechnoTrend, and the problem occurs on both cable and sattelite. With DVBViewer 4.9.0 everything is working fine. Quote
bogdan1980 Posted March 19, 2012 Posted March 19, 2012 (edited) confirm this bug on dvb-c channels, a lot of my channels does not work with 4.9.5, back to 4.9 Edited March 19, 2012 by bogdan1980 Quote
Derrick Posted March 19, 2012 Posted March 19, 2012 try uncheck -> options -> TV+Radio -> "fast channel switching" Then a complete tuning sequence is sent from the client even on the same tramsponder. Maybe zapping will be a little slower Quote
iriskin Posted March 19, 2012 Author Posted March 19, 2012 try uncheck -> options -> TV+Radio -> "fast channel switching" Then a complete tuning sequence is sent from the client even on the same tramsponder. Maybe zapping will be a little slower At least for me it did not work but thanks for trying to help us. Quote
Kiwi_Tim Posted March 20, 2012 Posted March 20, 2012 try uncheck -> options -> TV+Radio -> "fast channel switching" Then a complete tuning sequence is sent from the client even on the same tramsponder. Maybe zapping will be a little slower It didn't work for me. Tim New Zealand Quote
bogdan1980 Posted March 20, 2012 Posted March 20, 2012 (edited) DVBViewer v4.9.5.1 fixed this. Edited March 20, 2012 by bogdan1980 Quote
Kiwi_Tim Posted March 20, 2012 Posted March 20, 2012 DVBViewer v4.9.5.1 fixed this. Ooops! Didn't see that. Yes, after installing the latest hotfix all is sweet! Tim, New Zealand Quote
