dmb4 Posted September 26, 2004 Posted September 26, 2004 I don't seem able to synchronise audio and video when recording (from Astra 19 or 28). I have used various versions of PVAStrumento before creating DVDs using TMPGEnc DVD Author. Am I missing out a vital step? Help! Quote
Technofriend Posted September 26, 2004 Posted September 26, 2004 What exactly are you doing? More infos. What exactly are the problems? Quote
dmb4 Posted September 26, 2004 Author Posted September 26, 2004 Hi Tecnofriend I record programmes (from Astra 19 or 28) in mpg format and then use PVAStrumento, (various versions), to turn the transmission stream into a program stream. When viewing the DVDs I created using TMPGEnc DVD Author the audio and video are not perfectly synchronised; the audio is a fraction of a second behind the audio. Am I missing out a vital step? Quote
gglasmacher Posted September 26, 2004 Posted September 26, 2004 Hi dmb4, you should try ProjectX, a free JAVA tool to demux and resync the PVA streams. I use it since about a year now and don't have any problems. Pleas do a search for ProjectX in the forum to find some more information about it and links where to download it. Regards, gglasmacher Quote
Technofriend Posted September 26, 2004 Posted September 26, 2004 Do you have a fast computer? Which demultiplexer do you use? M$, Elecard?? Is the async also to be seen on a standalone? Is the async only in speech? It maght be a syncrnization from another language? Try projectX. BTW: Please don't use PM for forum-topics. Quote
dmb4 Posted September 26, 2004 Author Posted September 26, 2004 Hi gglasmacher Thanks - I will look for ProjectX. To Tecnofriend - I have An Intel 2.8 PC. As I said, I have used PVAStrumento, (various versions), to turn the transmission stream into a program stream or to demux and then TMPGEnc DVD Author to burn DVDs to be viewed using a Panasonic 'standalone' DVD player. I have not used M$ or Elecard. Do you think I should? The programs I have recorded are not dubbed, i.e. they are original language programmes, recorded from BVN (Dutch), Canal Canarias (Spanish) and various BBC (English) channels. The results are consistently out of synch; I just mentioned speech because lip-synch is easier to spot. Quote
Technofriend Posted September 26, 2004 Posted September 26, 2004 >I have not used M$ or Elecard. Do you think I should? No need then. I thought this could be the problem. But then it would only be while watching the DVD on the Computer. >they are original language programmes so it's not a language-conversion-problem either. I use pvastrumento latest version and ifoedit here and it seems to work nice. But TMPGEnc should be fine as well. Its a nice program. Quote
