Dvbviewer startup: Synzip popup ?!
themaster1
I can't start DVBViewer today, first time this happen to me in 3 years probably
A window pops up " SynZip -3" what the hell is that ?
I'm not sure if it's related to the fact i have installed a new software today or not (mpeg2 encoder from mainconcept).
I need a solution asap thanks
PS: if you need a support log let me know (i don't remember how all this works)
use the current version. Read the changelog.
Actually DVBViewer works but this annoying synzip window is not fading away .I'll try the newest version and report
I got this error today first time ever and of course upgrade to 4.9.5.1 and everything is OK for now :biggrin:
Well i have installed the v4.9.5 and guess what, nothing work now:
- no video or audio on DTT/SAT
- all channels on my DTT favorites channels list are grayed out
I have chosen "modify existing setting" and installed Lav A/V filters that's it what did i do wrong ?
Edited by themaster1
Looks Like You Have A NEW BUG.....DVBViewer Pro V4.9.0.0 Win Xp Pro SP3.... I have it as well after a reboot.
I had to restart my test machine just after midnight to load a registry change testing a remote control on several media players.
and the bug SYNZIP -3 popped up (the other media players appear unafected)
all was OK just before the restart.
I rolled back my registry change no effect... still have SYNZIP -3 popup. (googled it says it is python??)
well as this is my test sytem, I have just started my living room system, it has the same error popup.........IT WAS OK JUST AN HOUR AGO.
Its my Bedtime I will create a support zip in the morning and post it.
I have not had a windows update today to my knowledge. looks like a friday the 30 march bug in python or sumsuch....
Best Regards
CellZapper
the current version is 4.9.5.1 and not 4.9.0. Are you able to read?
you bug is known and fixed
I had this problem too on my v4.9.0.0 in an old, updated Windows XP Pro. SP3 machine. I thought it was related to Flash upgrades I got since I didn't have this error on Monday night. Sheesh! I upgraded DVBViewer Pro, and no more problems. :)
Thank you for pointing out my stupidity
I had only installed 4.9.0.0 three weeks ago, I stupidly thought I was up to date.
I will of course update to 4.9.5.1 ASAP.
I wish you guys would tollerate fools like me with a more polite response to my (I thought helpfull) addition to a bug report. Put it down to being 0200 hours and we are all tired.
Thank You For prompt 24 hour support, it is well appreciated.
CellZapper
Any idea of what's going on with my setup ? I can't use my cards really
Well i have made a fresh install, seems to work fine now
