Codepage in EPG fileinfo
jhrdlicka
Latest DVBViewer and RS do not have the same codepage format in EPG infofile.
Saving EPG from DVBViewer is utf-8, from RS is unicode.
My Notepad have problem show correct language(latest RS).
Older RS did not have with codepage in EPG info problem .
Can I change codepage for epg infofile in RS? An idea?
Jose
Jose
For the record, UTF-8 is unicode. Both DVBViewer and RS should produce info files encoded in UTF-8 without BOM. It's important to not change this file encoding to either UTF-8 or ANSI, cuz if doing that it could cause havoc if used for rebuilding the RS recordings database.
Edited by majstang
I mean rather that both logos are the same and I did not have to convert before I open it with notepad.
latest version repaired this problem, epg info saved as previously
