Aspect Ratio
Problem with Aspect ratio
I have been puzzled by the reaction of the aspect ratio settings.
I have just done a fresh install with DVBViewer 4.9.6.11 to be sure nothing is left over from other installs.
Not too sure if anything else is lurking in the registry.
When I choose "Auto" or "16:9" for aspect ratio I get the correct size picture on the screen (with the black bars top & bottom).
So I can zoom 50% or 100% and all works well (see picture via link below).
Now this will display a black bar on top & bottom when the transmission is 1440 by 1088 (BBC One HD & ITV 1 HD in the UK).
Now I used to use best width (I think this was OK in 4.9.5 of DVB)and that worked fine.
When I do best width now (with 4.9.6.x ) the screen is expanded to 1920 Horizontally and 1088 vertically (my monitor is 1920 by 1240).
What I want to achieve is to keep the original picture intact (ie resize by just taking the black bars off) to size 1440 by 800 (which is the actual picture size).
According to the manual:
Auto: The DVBViewer automatically sets the aspect ratio according to the data transmitted with the TV picture. This is the default setting, which will give good results with most broadcasts.
Does this mean best picture without the black bars??
Looking at support.zip
TweaksPro.ini section 27 describes this:
[27]
Section=Display
Ident=BestHeight
Type=Boolean
Default=0
Caption=Best window size only by changing the height
CaptionG=Beste Fenstergröße nur durch Änderung der Höhe
Description=Affects the automatic video window adjustment to the current aspect ratio. On: The window size is only adjusted by changing the height. Off: Either the height (for 4:3 monitors) or the width (for non 4:3 monitors) is changed.
So the question is: Is there a way to get 1440 by 800 (so I need to loose just the black bars) picture size on a 1440 by 1088 (16:9 transmission).
Many Thanks
I enclose support.zip
Pictures are here:
See pictures
Edited by fxv1
Hello,
try "none" as aspect ratio setting.
Tried that as well, that just strecthes the picture to fill the black bars ending with everything stretched vertically. So everything looks tall.
What I want is for the 1440 by 1088 transmission to end at 1440 by 800 (which is the picture portion, ie 1 to 1 pixels)
Frank
1440 x 1080/1088 needs to be watched at 16:9 ratio or it will be distorted. What kind of screen are you watching on?
Edited by dvbrewer
Yes looks fine when watched at 16:9 (or Auto).
But how to remove the black bars.
I am watching on a 1920 by 1240 monitor. (HP ZR42w)
It will be either an undistorted picture with correct AR=16/9 and black bars or a full screen without bars but with a slightly vertically strechted picture. For the latter you have to select AR -> None
Use a zoom preset i.e. right click>zoom>recall drag to where you want, you can set a remote button to cycle through the zoom presets (recalls).
Have messed around with the zoom presets, still experimenting.
By the way any idea how to relate to the values in the actions.ini file
Zoomlevel Standard=16389
Zoomlevel 0=16390
Zoomlevel 1=16391
Zoomlevel 2=16392
Zoomlevel 3=16393
Zoomlevel Toggle=16394
so my target here is to set one zoom at 1440 by 800
Thanks
Frank
