FreakshowDK Posted May 4, 2012 Posted May 4, 2012 Sorry to bother you again :-( I did a clean install of win 7 and now DVBViewer dosnt recognize the dvb-c in my hybrid usb tv card Hauppauge 930c. I am running DVBViewer 4.6.9.20. Transedit says "initializing the dvb devise has failed". I have tried with the database file "OldEMPIADriver_BDADevices.dat" and it comes up with two new devices, but still no hardware avaiable. I have tried to do what i did last time i had problems My link but i cant seem to make things work. support.zip I hope someone can help me Quote
Lars_MQ Posted May 4, 2012 Posted May 4, 2012 remove the bdadevices.dat. Enable Automodulation in the DVBViewer -> Hardware options. Quote
FreakshowDK Posted May 4, 2012 Author Posted May 4, 2012 remove the bdadevices.dat. Enable Automodulation in the DVBViewer -> Hardware options. Thank you for your answer, but unfortunately "force auto modulation" dosn't do it :-( Quote
FreakshowDK Posted May 5, 2012 Author Posted May 5, 2012 I tried changing vendor fron 28 to 4 in the appdata>DVBViewer>cmuv>hardware.xml like i did when i had problems with 4.8.1.0, Maybe there is a solution for DVBViewer Pro 4.8.1. Please try the following: - Close DVBViewer Pro - Open the file hardware.xml in the configuration folder with a text editor and change the value 28 in the entry <entry name="Vendor">28</entry> for the DVB-C tuner to 4. - Save the changed hardware.xml and relaunch DVBViewer Pro. It should now behave like the TransEdit test version with "Force Auto Modulation" unticked. Please note: Performing Options -> Hardware -> Scan Devices restores the previous value! but it seems like adding this string to the hardware.xml <entry name="useMSNP">1</entry> did the trick :-D I do not know what usemsnp does exactly, but everything is fine and i'm not getting the no hardware available message anymore For info i do not use the OldEMPIADriver_BDADevices.dat and there is no "force auto modulation" option anymore in the DVBViewer>settings>hardware Hope this can help someone Quote
