AllenConquest Posted October 7, 2004 Posted October 7, 2004 The title says it all. Can I run both these cards in the same PC and use DVBViewer (or any other software) to control both of them. I'd probably want to be able to view satellite while recording terrestrial, is that possible ? Thanks for any help, Allen Quote
Hartwig Posted October 7, 2004 Posted October 7, 2004 It might be possible. But at the moment the DVBViewer runs only with one of them at the same time. Quote
Klausing Posted October 8, 2004 Posted October 8, 2004 At the momoent there is no real successfull solution to run both cards in same system on different transponders. Some people tested it but with not so much luck. Steffen Quote
AllenConquest Posted October 18, 2004 Author Posted October 18, 2004 Can DVBViewer be used with any other DVB-T card ? I really want to put together an HTPC system that combines DTT and Satellite, but can't find any software that can do this. Does anyone know of a software package that will allow me to combine DVB-S and DVB-T cards in one machine ? Thanks, Allen Quote
Guest Lars_MQ Posted October 18, 2004 Posted October 18, 2004 The only software capable of working with more than one DVB card is as far as I know VDR. Unfortunatly it works only with linux... lars Quote
Derrick Posted October 18, 2004 Posted October 18, 2004 The title says it all. Can I run both these cards in the same PC and use DVBViewer (or any other software) to control both of them. I'd probably want to be able to view satellite while recording terrestrial, is that possible ? Thanks for any help, Allen I'm not sure, but if you use different applications for both cards, why not? Quote
Klausing Posted October 18, 2004 Posted October 18, 2004 if you cant select the card in application it should not work, because both would youse the 1. card...... 2 different appliction would use the same driver with same card... But anyone wrote in TV4pc you can select the card. So you could use it to view on the second card and for the first card you can use the DVBViewer for recording. let us know if its work... Steffen Quote
