laptribe Posted June 9, 2012 Posted June 9, 2012 (edited) hi i just purchased and installed DVBViewer 4.9.6.20 i registered it with my key and all info and set it up when i open it to do anything it closes i try to scan for channels it closes i try to select a channel from the default Astra list and it crashes gone through a uninstall/reinstall process once which sadly did not make a difference editied to add: my hardware is recognized by DVBViewer and i added a video here to show you my issue attached is my support file support.zip Edited June 9, 2012 by laptribe Quote
McenterFreak Posted June 9, 2012 Posted June 9, 2012 hi i just purchased and installed DVBViewer 4.9.6.20 i registered it with my key and all info and set it up when i open it to do anything it closes i try to scan for channels it closes i try to select a channel from the default Astra list and it crashes gone through a uninstall/reinstall process once which sadly did not make a difference attached is my support file You have a "bad" win install, reinstall Win and DVBViewer, and everything will work Quote
MarkVent Posted June 9, 2012 Posted June 9, 2012 I'd wait for one of the DVBViewer support guys to look at the issue first ... reinstalling Windows is a bit of a long shot and I can bet M(edia)centerFreak will be long gone by then when that DOESN'T work ... I'd say its a either a driver or hardware compatibility issue - DVBV official support should be able to sort you out. Quote
McenterFreak Posted June 10, 2012 Posted June 10, 2012 I'd wait for one of the DVBViewer support guys to look at the issue first ... reinstalling Windows is a bit of a long shot and I can bet M(edia)centerFreak will be long gone by then when that DOESN'T work ... I'd say its a either a driver or hardware compatibility issue - DVBV official support should be able to sort you out. Then i say: Have patience And you are completly rigth, i wont take resposability for your configuration after a reinstall, but do as you want, sit still and wait, and wait, and wait They will answer, maybee But if it was my problem, I would do a reinstall (1 hour) install drivers and DVBViewer, then look at TV, all happy Quote
