Blue Fishey Posted July 20, 2012 Posted July 20, 2012 Morning Interesting one this, it worked fine Then when you start it Crash Problem signature: Problem Event Name: APPCRASH Application Name: DVBViewer.exe Application Version: 4.9.6.20 Application Timestamp: 2a425e19 Fault Module Name: StackHash_9d66 Fault Module Version: 6.0.6002.18541 Fault Module Timestamp: 4ec3e39f Exception Code: c0000374 Exception Offset: 000abc4f OS Version: 6.0.6002.2.2.0.256.1 Locale ID: 2057 Additional Information 1: 9d66 Additional Information 2: 4fea11e21c720347e48eb4b0b2c53ea0 Additional Information 3: 659f Additional Information 4: 8e60d5e923c8315aad1fd65e5e3809fd emmmm, so usual reinstall do a scan watch, then close then try to open crash The only thing I think is of you close while watching Freeview HD it then crashes on restart Vista Ultimate x64 x58 Chip Set Blue support.zip Quote
Blue Fishey Posted July 23, 2012 Author Posted July 23, 2012 Defo Close 4.9.6.20 on a SD channel no prob opens fine Close on a HD channel is crahes on restart ! Help Blue Quote
majstang Posted July 23, 2012 Posted July 23, 2012 Perhaps if trying an another H.264 decoder. Crashes like this usually happens if using some odd decoder often installed by various codec packs. Cyberlinks decoders are stable and preferably. Quote
Blue Fishey Posted July 23, 2012 Author Posted July 23, 2012 how do u run the options to change codecs without running up DVBViewer ? Quote
Blue Fishey Posted July 23, 2012 Author Posted July 23, 2012 look sorted downloaded http://www.cccp-project.net/ Quote
bogdan1980 Posted July 27, 2012 Posted July 27, 2012 cccp is crap, use klite full edition, not mega. Mega is full of crap Quote
