Dark Avenger Posted July 22, 2012 Posted July 22, 2012 Hi all, I have a problem with the latest Recording Service. Latest version of Recording Service 1.10.0.0 prevents my Windows 7 x64 SP1 machine from going to sleep. Neither key combination, Start -> Sleep or by timer work. With the previous version 1.9.7.0 everything is working fine. Is this a known problem? Could you address it in the next version? Thanks in advance.
Lars_MQ Posted July 23, 2012 Posted July 23, 2012 There is no known problem. Please post support.zip.
blasgl Posted July 23, 2012 Posted July 23, 2012 and post the output of this command when the "problem" is occurrung: powercfg -requests
Dark Avenger Posted July 23, 2012 Author Posted July 23, 2012 When the problem occur the result from the powercfg -requests is: DISPLAY: None. SYSTEM: None. AWAYMODE: None. If I manage to put my computer to sleep after several retries the result is: DISPLAY: None. SYSTEM: [sERVICE] \Device\HarddiskVolume3\Program Files (x86)\DVBViewer\DVBVservice.exe (DVBVRecorder) AWAYMODE: [sERVICE] \Device\HarddiskVolume3\Program Files (x86)\DVBViewer\DVBVservice.exe (DVBVRecorder)
Dark Avenger Posted July 23, 2012 Author Posted July 23, 2012 Here it is the support.zip as requested.
Jens Remus Posted July 24, 2012 Posted July 24, 2012 (edited) Lars, I do not want to hijack this thread, but my case it is just the inverse of this one. The Recording Service just does not prevent my Windows 7 64-Bit SP1 HTPC from going to standby, although it is currently recording. Could you please have a look at my issue here: RS verhindert Standby während Aufnahme nicht zuverlässig. Thanks in advance, kind regards, Jens Edited July 24, 2012 by Jens Remus
Dark Avenger Posted August 28, 2012 Author Posted August 28, 2012 Issue is still there with the latest version 1.20.0. The last version that allows my PC to go to sleep normally is v1.9.7.
bogdan1980 Posted September 20, 2012 Posted September 20, 2012 (edited) For me , 1.21.2 is the single one that let my PC enter standby. I use DVBViewer for 4-5 years, but with all other rec services, my PC never enters standby if DVBViewer rec service is activated. Till yesterday, when i notice that my PC enter standby if i do not use rec service. I use some app on Iphone and on Android to wake up my pc. Now powercfg look like this: DISPLAY: None. SYSTEM: None. AWAYMODE: None. Before rs 1.21.2 in powercfg i see dvbrec even if nobody acces DVBViewer or rec service. Edited September 20, 2012 by bogdan1980
