gucky Posted October 12, 2004 Posted October 12, 2004 i think it is a good idea to implement the following features into the DVBViewer: a default setting for the action the DVBViewer executes, when a recording is done. in this moment you have to control in every programing what the DVBViewer should do. i use the DVBViewer scheduler. so when i program a recording i have to control every time what the DVBViewer does after the recording. every time i habe setup the DVBViewer to close itself. i think it is a good idea do include the vrplugin into the DVBViewer. when i wand to record manually i can't record in the ts format because the ts format is not a native DVBViewer format. in the last time i tried to setup the DVBViewer to use the mpeg2 decoder from the ffdshow package ffdshow20041003. this decoder i can't use in the DVBViewer. i can't select the filter in the dialog in the dvbiewer. gucky Quote
Guest Oliver Posted October 12, 2004 Posted October 12, 2004 think it is a good idea to implement the following features into the DVBViewer: a default setting for the action the DVBViewer executes, when a recording is done. in this moment you have to control in every programing what the DVBViewer should do. i use the DVBViewer scheduler. so when i program a recording i have to control every time what the DVBViewer does after the recording. every time i habe setup the DVBViewer to close itself. I've put this one on the "work in progress" list. Bye, Oliver Quote
Griga Posted October 12, 2004 Posted October 12, 2004 in the last time i tried to setup the DVBViewer to use the mpeg2 decoder from the ffdshow package ffdshow20041003. this decoder i can't use in the DVBViewer. Select <Auto>. This will usually let the DVBViewer use the FFDShow MPEG2 decoder. Somehow FFDShow doesn't report the required format when the DVBViewer checks the available filters I've already tried it - not very convincing, at least for DVB. Stop and go with the DVBViewer Filter, fast channel switching problems with Marfi's filter... other freeware decoders worked much better (DScaler, XYMpeg...) Quote
