bogdan1980 Posted August 3, 2012 Posted August 3, 2012 Here are Romanian Channels Logos for both RDS and UPC( Astral). https://rapidshare.com/files/4107326334/ChLogos.rar http://depositfiles.com/files/0qpta35ms http://www.sendspace.com/file/1f204j http://speedy.sh/xm2yF/ChLogos.rar Put them into c/program files/DVBViewer/images/logos. Sometimes, RDS change channel name: example : Cinemax became Cinemax (rum), and logo is named: Cinemax, sometimes logo does not shown and you need to rename logo exactly as channel name. If you want to have logos on Iphone also, you need to use .png extension. In this pack we have .png, but in future for new channels you need to use .png. If you have an .jpeg logo ,open it in mspaint and save it : save as .png and you will appear on iphone as well. Enjoy. Quote
djsorin Posted October 8, 2012 Posted October 8, 2012 Slab pachetul, zilele astea o sa pun eu logo-urile facute de mine in format png si cu transparenta. Quote
alexdonc Posted October 9, 2012 Posted October 9, 2012 Nu am timp ca le-as pune si eu... Chiar pe site-urile providerilor gasim. Quote
alexdonc Posted January 24, 2013 Posted January 24, 2013 Uite si o versiune actualizata cit de cit pe care o folosesc eu in momentul de fata chiar daca nu este perfecta.... https://dl.dropbox.com/u/25345141/rds-logos.zip Quote
alexdonc Posted March 6, 2013 Posted March 6, 2013 I'm having a hard time now to refresh channel logos in RS's database. I have copied the logo files where I suppose to, the DVBViewer shows them but I can't see squat on clients connected to RS - like BubbleUPNP or my Samsung TV... Is there any trick to solve this? Thank you. Quote
fchobee Posted February 22, 2017 Posted February 22, 2017 (edited) Am facut logourile de la RDS cu cateva lipsuri (fara "tarafe" si "realitatea" virtuala ) Sunt albe si cu background transparent. https://mega.nz/#!I4JlAKyL!tbT0E744iNZXlA9fQRidWzBW5FhzfpqNa2m2YhYVoIY Edited February 22, 2017 by fchobee Quote
fchobee Posted February 23, 2017 Posted February 23, 2017 (edited) Edited February 23, 2017 by fchobee Quote
rodjd Posted April 13, 2017 Posted April 13, 2017 si cand le faci pe toate ? cu radio cu tot parca sunt 166 nu? Ce OSD folosesti? Arata titlul intreg de exemplu la un meci de fotbal ? De-a liungul Loarei - sa scrie Rapid Bucuresti vs Real Madrid ..intalegi Quote
fchobee Posted April 19, 2017 Posted April 19, 2017 OSD e "X-Skin Black Glass MOD" editat de mine... 1 Quote
rodjd Posted April 22, 2017 Posted April 22, 2017 On 19.04.2017 at 6:17 AM, fchobee said: OSD e "X-Skin Black Glass MOD" editat de mine... Nu imi dai si mie OSD-ul editat de tine,daca zici ca scrie intreg la titlu si pe cand faci toate logourile ? Quote
fchobee Posted April 26, 2017 Posted April 26, 2017 Toate logourile de la posturile RDS + x-skin blackglass modificat https://mega.nz/#!khA0nDCA!szUMfYtMIAjJW8FXQmQ97SRHxPJ1vn168EIwsxv7ccg Quote
constantin2015 Posted April 28, 2017 Posted April 28, 2017 (edited) salutare, folosesc ultimul DVBViewer (6) si MediaServer 2 cu cartela de Digi, ma puteti ajuta pe privat sa fac lumina pe unele canale? Mersi mult Edited April 28, 2017 by constantin2015 Quote
rodjd Posted April 28, 2017 Posted April 28, 2017 On 26.04.2017 at 10:11 AM, fchobee said: daca vrei sa faci un update in stanga sus sa se vada numarul canalului exemplu:10 "DIGI Sport 4",acel patratel nu isi are rostul (parerea mea) eu folosesc acum OSD-ul blackglass dar nu modificat pentru ca nu arata numarului canalelor,la titlu tot mai arata ... cand este prea lung ai facut poate ceva setari la font-uri ? Quote
fchobee Posted May 2, 2017 Posted May 2, 2017 problema e ca cei del a RDS sunt niste idioti, nu asa se face un epg normal, In loc sa scrie la titlu: FCSB-Dinamo si la rezumat: meci din epata x-spea din play off, ei scriu la titlu: Digisport special Fotbal liga 1: FCSB-Dinamo Bucuresti si te mai miri ca nu incape pe televizor. In fine am micsorat fontul si am bagat numarul la nume canal. https://mega.nz/#!oppxRQxT!1ILWYGybZFAgGig4JOd0bGpmFPXrLvjYMf__SEv_At4 Arata cam asa: Quote
rodjd Posted May 4, 2017 Posted May 4, 2017 super #fchobee dar cum pot elimina si patratelul -exemplu "DIGISport 3" din stanga ...mie unul nu imi trebuie Quote
fchobee Posted May 5, 2017 Posted May 5, 2017 pai sterge logourile de aici c/program files/DVBViewer/images/logos Quote
rodjd Posted January 23, 2018 Posted January 23, 2018 (edited) Mai poti face un update sa aduci patratul cu logo-urile canalelor in stanga jos si daca se poate sa le pui pe toate color si HD,merci Edited January 23, 2018 by rodjd Quote
rudybloch Posted May 5, 2018 Posted May 5, 2018 On 4/26/2017 at 9:57 AM, fchobee said: Toate logourile de la posturile RDS + x-skin blackglass modificat https://mega.nz/#!khA0nDCA!szUMfYtMIAjJW8FXQmQ97SRHxPJ1vn168EIwsxv7ccg Poti sa refaci link-ul te rog, merci. 1 Quote
rodjd Posted October 19, 2019 Posted October 19, 2019 numai functioneaza nici un link ! not work link ! Quote
bogdan1980 Posted October 26, 2020 Author Posted October 26, 2020 Romanian logos: https://www47.zippyshare.com/v/uGbjoZom/file.html romanian language: arhiva se dezarhiveaza, si tre pusa in c/ program files 86/DVBViewer/images/logos in LOGOS pui direct imaginile. daca nu merg toate, le iei de manuta: DVBViewer-settings-channel logos, in ecranul asta faci scroll si te uiti la logo vs canal tv, daca ceva nu e in regula dai click pe logo respectiv si cu browse pui alta imagine. english language: put images from archive in c/ program files 86/DVBViewer/images/logos( in logos you put the images, not folder in folder.... Quote
rodjd Posted December 25, 2020 Posted December 25, 2020 (edited) ^linkul care l-ai pus este mort ! Pune si tu un link ceva ca sa dureze,te rog ! Edited December 27, 2020 by rodjd Quote
alexdonc Posted April 30, 2021 Posted April 30, 2021 Chiar așa. Total neactualizate... Dar îmi e o lene. M-am apucat totuși să le refac astăzi. Hai că dacă le termin le pun aici. Promit ? Quote
rodjd Posted December 30, 2021 Posted December 30, 2021 aveti transporder pentru scanare la digi ? asteptam logourile dar se pare ca nu mai vin ... Quote
