Zühtü SARIOĞLU Posted August 12, 2012 Posted August 12, 2012 how does it work with DVBViewer ip tv? 1
Tjod Posted August 12, 2012 Posted August 12, 2012 For DVB-over-ip > add a IPTV Network Device and than you have to add the channels via TransEdit http://en.DVBViewer.tv/wiki/Options_Hardware#Device for web streams you have to put the URL in a play-list an open the play-list like a media file.
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 what is network device? I have happuage dvb/s2
Tjod Posted August 12, 2012 Posted August 12, 2012 Are you taking about receiving DVB-over-ip or dvb-S? http://en.wikipedia.org/wiki/IP_over_DVB I don't understand your question.
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 I have happuage nova hd s2. ip tv no problem?works correctly?
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 DVBViewer do not understand how it works with the IP TV. nova hd s2 digital tv card and DVBViewer now have on my computer. soryy
Tjod Posted August 12, 2012 Posted August 12, 2012 IP TV and DVB-S are different things. Du you have a problem with IP TV or with DVB-S?
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 Yes. How to connect to the DVBViewer iptv. thanks
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 DVBViewer options-hardware-+push-iptv network device ok. What do I do now. the next operation?
Tjod Posted August 12, 2012 Posted August 12, 2012 Depends on the kind of Streaming you are talking about. There are different Streaming technique which need different procedure to get it working.
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 I think add m3u file in DVBViewer. after options open iptv run maybe ,
webmaher Posted August 12, 2012 Posted August 12, 2012 Just add m3u file with TransEdit and export to DVBViewer, where you must have IPTV Network Device enabled... IP TV just work excellent
Zühtü SARIOĞLU Posted August 12, 2012 Author Posted August 12, 2012 How to add a m3u file how transedit program?
Tjod Posted August 13, 2012 Posted August 13, 2012 No crossposting pleas. Keep one of your problem only in one topic. To import DVB IPTV playlists .m3u files (it will only work with DVB over IP playlists not with other .m3u files) "install" TransEdit http://www.DVBViewer.com/griga/TransEdit%20E/General.html#Installation File > Open >> Filetype >> .m3u > sect the DVB IPTV playlists > open > Scan all http://www.DVBViewer.com/griga/TransEdit%20E/MainWindow.html#Scan select all channels > Add / Update http://www.DVBViewer.com/griga/TransEdit%20E/ScannerWindow.html#ChannelList
Anna Maria Mazzini Posted September 12, 2017 Posted September 12, 2017 (edited) On 13/8/2012 at 5:26 PM, Tjod said: No crossposting pleas. Keep one of your problem only in one topic. To import DVB IPTV playlists .m3u files (it will only work with DVB over IP playlists not with other .m3u files) "install" TransEdit http://www.DVBViewer.com/griga/TransEdit%20E/General.html#Installation File > Open >> Filetype >> .m3u > sect the DVB IPTV playlists > open > Scan all http://www.DVBViewer.com/griga/TransEdit%20E/MainWindow.html#Scan select all channels > Add / Update http://www.DVBViewer.com/griga/TransEdit%20E/ScannerWindow.html#ChannelList Hi, I am sorry. I tried all fof this above but every M3U playlist file I open, Transedit doesn't recognize anything: I can't SCAN ALL... Can I please have an example of M3U playlist format suitable for transedit and then DVBViewer? Thank you so much in advance... P.S.: Hope that someone answer me because I know the thread is old enough... Edited September 12, 2017 by Anna Maria Mazzini
Tjod Posted September 13, 2017 Posted September 13, 2017 The information in this topic is about a old version. Posting in a Topic where the last post was years ago is nearly never a good idea. Instead of posting in an old topic, make sure you are using the current DVBViewer Pro version 6.0.3. And read the beginning of this Topic: http://www.DVBViewer.tv/forum/topic/59624-DVBViewer-600/ Added: Channel List: DVBViewer Pro 6.0 provides an easy way to ... The DVBViewer only supports TS streams no Flash or other video container formats. If you still have problems start a new topic.
